One of the trade offs with the latest Rav4 body in general is the snap on fender "flare"s and lower door panels cladding. These are an easy way to alter a base sheet metal body and may have some minimal aerodynamic effect but they are also form a pinch point between the snap in panels and the underlying paint. Up in the sand and salt zone grit will get caught up in this pinch point and eventually cut into the paint forming a rust spot once the aggressive deicing chemicals used these days get to the underlying steel. I had a GMC Syclone at one point that had similar cladding and after 4 winters of actually driving it, it had numerous rust spots starting to blossom under the flares at the pinch point. I ended up selling it for not much less then I paid for it but if I had kept it, all the cladding would need to be removed and the all the rust spots attended to before a repaint would be needed. My Land Cruiser LJ70 arrived with the factory flares removed but all the holes drilled in the body with some crappy aftermarket flares covering the holes. Luckily it came from somewhere in Europe where rust did not appear to be an issue so the body was rust free. The stock Toyota flares for the LJ that I purchased and installed used some skinny rubber lip seals along the edges of the flares to seal off this opening but I saw evidence of a very distinct wear line in the paint that lined up with the lip seals from the past. In my opinion the lips seals kept out the course grit but not fine grit and the fine grit was slowly grinding through the paint.
My guess is the typical typical Prime buyer will have moved on to the next hot model before its an issue but my usual plan is to keep a vehicle for 7 to 8 years. So thoughts and opinions?
I have heard of three approaches to dealing with this. One is to remove the cladding yearly and clean out any grit to delay the inevitable and catch any bad spots early. The other is remove the cladding and weld up the holes and leave the cladding off (aesthetically not very pleasant). The other option I have seen is to pop the cladding and seal the edges of the cladding where it meets the body with an alcohol based silicone sealant (GE silicon 2) and carefully smooth out the resulting bead between the cladding and the body when its reapplied. This prevents the grit from getting in but no seal is perfect so it could trap moisture behind it. My guess is the silicone might look like its bonded to the paint early on but unless the paint is roughed up the bond might fail. My plan is to pop the cladding next spring and see if there are areas of concern.
