1 - 10 of 10 Posts
I own a 2010 RAV4 and both my fans aren't working , my compressor is good and I have enough refrigerant in the system but my fans are just not working can someone help..?
First thing I'd check is the fuses.
Reactions: Big Bird
Please provide more info on how this led up to the you knowing the fans are not working. Any repairs done?
Well about 2 years ago I had my compressor replaced and then this summer season I turn on the a/c and it's blowing mild air so take a look underneath the hood and I noticed that my fans aren't working
I thought it was the compressor again but after a mechanic checked it out he also noticed that the fans weren't working as well. What could it be? I want to be informed when I go to get it fix because I don't want to get jerked.
Depending on the ambient temp just idling the engine for a few minutes should start at least one fan w/o the A/C on. So that would be my first test. If it passes that the A/C system could be low on refrigerant which would keep it from even trying to work.
You could always disconnect the fan and apply the correct voltage (12v?) and polarity directly to the fan. If it spins you have a fault in the control circuit/logic. If it doesn't spin you fave a failed fan.
When your mechanic checked it out, couldn't he have checked as to why the fans weren't working?
Reactions: ravenuer
1 - 10 of 10 Posts
