What size is your air compressor? How much CFM and tank size. 6-7 minutes on the wheel furthest from the master cylinder seems like a long time.
The compressor is a small Craftsman unit intended for construction work - pneumatic nailers and the like. According to the label on the 3 gallon tank, its [email protected]; [email protected] The line pressure was ~90psi.What size is your air compressor? How much CFM and tank size. 6-7 minutes on the wheel furthest from the master cylinder seems like a long time.
The thing that comes to mind is... how does your bleeder attach to the bleed screw? What does the attachment part look like?I<snip>I have a similar brake bleeder and I can drain the master cylinder from the back wheel in less than a minute on a big truck. That may seem like an issue with having to fill the master cylinder. I just tighten the bleeder valve and then shut off the brake bleeder and walk around and top off the brake fluid. And repeat until the fluid is clean.
There is no bleed screw. Just pull the trigger.The thing that comes to mind is... how does your bleeder attach to the bleed screw? What does the attachment part look like?
Your unit has to attached to the brake bleed screw in some way.. One possibility is simply squeezing the hose over the outboard tip of the bleed screw. This weekend, I'm going to try that - one less joint to leak.There is no bleed screw. Just pull the trigger.
Let me tinker with this over the weekend. I thought about attaching the hose directly to the bleed screw. That's what I would do in the past, in a 2-person bleed procedure. The small black 90deg angle attachment gizmos are handy but far from essential.Sorry, I miss read your earlier question. Yes there is an intermediate piece that is being used in that picture I posted above. I however don't use it. I just connect the clear vinyl tubing directly to the bleeder screw. It connects tightly and seals well. No vacuum leaks.
