2007 Rav4 Sport V6
About six months ago I replaced the brake vacuum booster with a new unit from Rock Auto. I had P0171 and P0174 codes, a hard brake pedal, intermittent rough idle, and the hissing sound from under the dash.
The hard pedal and rough idle went away but I am still getting P0171 and P0174 intermittently. Yesterday I also got a P1578. I still hear the hissing sound under the dash.
The question:
I still hear the hissing sound under the dash. Is that normal for a Rav4? It is not normal in any other car I have owned. Is the new brake booster defective?
2007 Rav4 Sport V6
That doesn't seem or sound at all normal to me. You'll need to find the source and fix it, but since I doubt any other members have the issue you'll have to sleuth it out yourself. When you do I suspect the other symptoms and codes will be cured.
So when you are sitting in your Rav4, engine running, you do not hear a hissing sound from under the dash?
Is there a vacuum dump valve for the cruise control?
No such sound on our RAV4.
With throttle-by-wire cruise control is electronic not vacuum.
I took another look/listen. At an idle i can hear a hiss under the dash. The engine is around 900 rpm. When I depress the brake progressively harder the hiss diminishes until I reach the end of the pedal travel and the hiss stops. The rpm's drop to around 600-700.
This is an A1 Cardone brake booster that I installed in July. I'm going to have to return it to Rock Auto. Has anyone else had problems with A1 Cardone boosters?
I have an 07 v6 limited. My booster is doing the same thing, hissing by the pedal. I have taken it to a shop to confirm its the booster and they said it was. Did you replace the booster yourself? And if so how did you get it out? I have taken out the master cylinder and disconnect the booster from the firewall and brake pedal but still can't get it out.
MrsT, maybe someone else will answer but I doubt a member we haven't heard from in 2 1/2+ years will. However we do appreciate your using the search option before posting.
