Well, I haven't gotten myself into this situation for a long time, but I'm afraid I've rounded the nut on one of my brake line fittings. Would love to get some advice/second opinions on how to proceed.
My 19-year-old son is about to take my 2011 RAV4 on a cross-country trip. It's got 111,000 miles on it and I think it's up to the task. But I decided to check some things over carefully and do a little preventative maintenance.
The brake hoses are the factory originals and while they appear OK, I figured after 10 years of service it wouldn't hurt to put new ones in (I'm servicing the brakes anyway so as long as I have easy access figure may as well do it).
Soaked all the fittings in penetrating oil in the morning (Mopar variety, works pretty well), gave them a second application at noon, and cracked the fittings loose with a 10mm flare nut wrench. All but one--the passenger side rear wouldn't budge. So I gave it another shot of oil, waited a couple hours, and tried it again. I put some effort into the wrench, which was properly seated on the nut, and it moved. Only it wasn't the nut moving--it was the wrench rounding over the corners of the nut. Ugh. I had to tap the wrench pretty good with a ball peen hammer just to get it free.
I soaked it again, let it sit overnight, and tried it again today. I took a small steel-wire "toothbrush" and cleaned above and below the nut thoroughly.
Still wouldn't budge--and if I really lean into it the wrench just slips.
I tried several times and it looks like I ended up bending the brake line slightly so it doesn't sit at a 90-degree angle from the nut anymore.
So...do I just stop and leave it be? My son is scheduled to leave next week and I'm afraid if I mess with it any more I'll be buying and installing a whole new brakeline which probably is going to delay his trip. As long as the fitting doesn't leak, it should be fine, right? Should I try bending the line back to where it's at the proper angle to the fitting or just let it be?
Any tricks to getting it off there with the nut rounded? Or do I just wait until he returns the car in November and tackle it then--being prepared to replace the whole brake line. If I do end up replacing that line I'd like to get a piece of cunifer in there. How long is that line to the passenger side rear? Does it run all the way from the master cylinder? Where's a good place to buy replacement prebent lines?
Thanks for any advice. Here's photos:
