21 - 27 of 27 Posts
Discussion Starter #21
Parts list
Control arms
Kyb shocks and struts
Ome springs
Uniroyal Laredo cross country tour 235/65r16
JVC kd-x560bt
Alpine pwe-s8
Led interior
Energy suspension poly bushing kit
Oem Toyota front diff mount
Dorman rear diff mount
Redline ns gear oil for manual awd transmission
Window visor
Egr
Vsv
Egr modulator
Keyless entry
oem rav4 wheel
Junkyard list
2x front seat
1x rear seat
Armrest
Dash
Hood
4x Door cards
Door lock
Seatbelt
Discussion Starter #23
Update!
I made a roof rack from 3/4in emt conduit. No welding involved. Just A LOT of drilling. I used pre bent 90 degree conduit and connectors for the corners since I didn’t want to buy the pipe bender.
165299
I painted it with truck bed liner to be more stealthy
165300
Here it is mounted with u-bolts and rubber wedged in between to reduce noise.
165301
It’s pretty sturdy. I hold onto the rook rack and pull myself up to access it with no problem. Haven’t had any wind noise from it yet. Will be getting a wind deflector in the front once I figure out what material to use. I was worried about tipping over since it is also lifted, but so far so good. I put my sleeping bag and chairs on it and I had no problems. Overall really happy with how it turned out and how much it cost. I think it is sturdier than the Amazon roof rack and cost less to make. It’s also technically modular and if I ever wanted to make it smaller or bigger I can change it around without having to spend anything especially with the materials I have left over.
1996 Toyota Rav4 (3 Doors, AWD, Manual)
WOAH! That is looking amazing!
If it's not too indiscrete... How much did it cost you? I am looking into buying a small roof rack for mine, but the price tag is making me feel like I'd rather spend that money on a mountain bike.
I am also curious as to how you flattened the extremities of the tubes. A hammer, or a bench clamp?
Discussion Starter #26
It cost about $100 without paint and tools. It’s about 6ft x 3ft. I tried using a hammer to flatten it but it was a lot of work and not that accurate. I eventually asked a friend to press them with a hydraulic press. If you had a sledge hammer and an anvil it would probably be doable. If you have proper tools for drilling cutting and flattening this would be a piece of cake, but I didn’t have that many tools so it was a lot more work.
I'll try and make it with a bench press! I can rent almost every tool at a local tool library.
Thanks for sharing this knowledge
21 - 27 of 27 Posts
