Well, it was above 40 degrees (F) out the other day so I decided to open the moonroof and enjoy the sun.
Noticed when I got up to 30 MPH, I started to get a buffering effect. Had to "crack" one of the rear windows to equalize pressure.
Anyone else have this issue? Any work arounds other than "cracking" a window? I know in Audi's you can't open the moonroof fully due to the same effect - they even have a position for it so it doesn't happen... Didn't really notice if the RAV has it.
The Rav has the same feature. If you press open, it opens 2" short of fully open to reduce the wind effect. The owners manual mentions it.
Harold said:
The RAV has the same feature. If you press open, it opens 2" short of fully open to reduce the wind effect. The owners manual mentions it.
I thought I read that before, but wasn't sure... Thanks.
Almost all cars that I've had with a sunroof were subject to this. Most do now have the two-position switch like a VW/Audi that doesn't open the panel fully unless you specifically want that. Personally I prefer the roof open all the way so I just crack the RR window.
On a similar note, in warmer weather I often drive with the driver's window all the way down. In most cars I've found that opening the RR window a couple of inches also reduces the buffeting you get from having the driver's window down.
yup with all windows closed and moonroof open i get buffetting.
DO NOT TILT MOONROOF UP AND OPEN REAR WINDOWS. When i got on the freeway and up to speed say 60 mph. This seems to hit the natural frequency inside the car and I almost blew out my ear drums not to mention the moonroof was waving up and down very hard. Huge amount of buffetting, like boom boom. :shock:
