21 - 37 of 37 Posts
Latest update from Toyota Canada:
NOTICE OF HEARING TO APPROVE THE SETTLEMENT​
PROPOSED CLASS ACTION CONCERNING SOME TOYOTA AND LEXUS HYBRID VEHICLES​
Constantin Sultana and Toyota Canada Inc. (“TCI”), the exclusive Canadian distributor of Toyota and Lexus vehicles, have reached an agreement in a proposed national class action.​
The Motion for authorization of the class action alleges that certain 2019–2022 model year Toyota and Lexus vehicles are affected by a latent defect in the hybrid wiring system, causing premature corrosion and failure.​
None of the above allegations have yet been proven in a court of law.​
This settlement, which must be court-approved, may affect your rights.​
Please read this notice carefully.​
WHO ARE THE GROUP MEMBERS?​
You are a member of the proposed class action if you are:​
Any individual, corporation, partnership or association that owns or leases, or has owned or leased, the following Toyota vehicles in Canada:​
Highlander Hybrid 2020-2022, RAV4 Hybrid 2019-2022, RAV4 Prime 2021-2022 Venza Hybrid 2021-2022; Sienna Hybrid 2021-2022​
Or the past or present owner or lessee of the following Lexus vehicle:​
NX350h Hybrid and NX450h+ plug-in Hybrid 2022.​
SETTLEMENT SUMMARY​
WHAT IS TCI OFFERING?​
Without any admission of liability by TCI or its affiliates, TCI agrees to implement a Warranty Enhancement Program (“WEP”) which extends the manufacturer’s warranty for all subject vehicles to eight (8) years or 160,000kms, whichever comes first, from the date of first use of the subject vehicle, and for repairs related to the alleged issue only.​
Under the terms of the WEP, any repairs required on a subject vehicle due to the alleged issue shall be performed free of charge by TCI. Members who have previously paid for such repairs before the release of this WEP, may be eligible for reimbursement even if the repair was performed by another dealer or an aftermarket shop.​
TCI will inform all members in writing by regular mail and by email to their last known address, if known, that their subject vehicle is covered by the WEP.​
TCI also agrees to pay the attorneys of Constantin Sultana’s fees of C$700,000.00 plus GST, QST, and disbursements in the amount of C$10,202.90. These amounts must be approved by the Court during the September 9, 2024 hearing.​
Where they have not fundamentally changed the design, why does this wep only cover 2019-2022??!? If you have a 2023/24 you are still screwed?
Discussion starter · #23 ·
Toyota will be very slow to extend the warranty until they have evidence that the changes they made haven't worked. That being said they have already recognized that the design is flawed so it's not a stretch to think the friction to extending the warranty is reduced.
When you look at the Car Care Nut video of the new AWD version of the hybrid Camry, that cable does not look exposed and there is no tray. Will this make its way to the next RAV? My guess is Toyota will run the clock out on this one with no further warranty extensions as the revisions will make for fewer failures.
As a few people have pointed out, the ultimate solution would be to alter the Rear Traction Motor Cable AND the HV Floor Underwire Harness to have a sealed/waterproof connector between them (which, if sealed properly, could be located in the same position it is now), but I'm not holding my breath. Toyota's offer/settlement of replacing a component which is expected to fail with another which is also expected to fail should have never been accepted as a solution, even from Toyota's perspective: do they really want to replace the HV Floor Underwire Harness (and possibly the Rear Traction Motor Cable as well) every couple years on qualifying RAV4s? I wouldn't think so.
That said though, the number of vehicles affected is substantial (I'm in eastern Canada and 5th Gen RAV4 HVs are EVERYWHERE....cant go a single small city black without crossing paths with one). Quite sure the 2023 connector revision is no better than the original (might be worse in some ways), and even if the 2024 revision lasts a little longer before failure, there are still going to be a lot of voices calling for restitution over the next few years. We just need to keep the pressure on.
Apparently it is sealed now on some 2024 models
Unfortunately that is not really sealed at all. Sealed would be if both halves of that entire assembly were embedded in cast-plastic housings with NO metal exposed at all. While it is better than the previous iteration (new red gasket at interface and the black boot over the mesh/clamp) there is still plenty of opportunity for salt-spray to reach the vulnerable material.
This is NOT a Toyota part, but is an example of what a sealed electrical connector might look like:
Aren't you folks up north covered? I have a warranty extension on my wife's 22 XLE hybrid but I love my Prime but it doesn't look like there will be an extension so it will be a 3 year car. I have a Ridgeline to use during the winter so that could by some time with the rust situation here in upstate NY.
So far that extension is for 19-22 (and we are assuming those people will get the latest iteration, whatever it may be, at time of claim). The 2023 iteration actually looks worse to me (completely exposes the mesh) and only time will tell how the 2024 iteration holds up. Its not just the mesh and clamp which corroded (though they seem to go the fastest), but the metal housing of the two reciprocal parts corroded as well... and those parts have not changed one bit (unless they are a completely different material, but their appearance does not suggest that).
This is just my opinion but I think that at very least it still needs a spray of Rust Check or equivalent if its to last (something which may or may not be "forbidden" under warranty).
Aftermarket rust treatments can make things worse, especially if improperly applied. Wire mesh is far more difficult to treat than a flat metal surface, for example. Solid coatings easily crack and peel in automotive environments. Wax and gels and greases work well in some applications, but around wire mesh they are less likely to be packed well enough to fill all the gaps and prevent water from seeping in. Liquid coatings need to be re-applied more frequently. If water can wick under the treatment, it can corrode even faster.
Someday, a motivated person will compare all the iterations and see if they have changed the metals and/or platings to reduce galvanic action, in addition to the physical changes of the assembly. Incompatible metals are the likely cause and changing them is really the best way to significantly increase the life of the part.
But who listens to AM radio? I'm old enough to know what it is at least LOL
AM radio means "radio that you listen to in the morning". Easy-peasy.
2022 R4P
Just got my letter today extending coverage on the cable to 8years/100k
I am 99% sure all hybrid components are covered to 8 years/100K miles, shouldn't be that cable as well by default?
I had mine replaced by the local yoter stealership under mentioned warranty, however I’m still getting the ‘hybrid system stopped’ light (the light came back less then a week after the ‘repair’) I took it in the dealership and they said they can’t find any codes. I really think that’s bs and they messed up on the TSB any advice for me here? Shouldn’t the code be stored in the vehicles ECU and the dealer can pull it?
Call Toyota Corporate and complain. (800) 331-4331. You'll hear from the dealer very quickly wanting to fix your issue. Dealers can lose their franchise if they get to many complaints from customers. Toyota is all about their reputation and saving face. When you call, get a case number so you can call back if the dealership is stupid. Good luck.
21 - 37 of 37 Posts
