I want to connect a camera to my rav4 2011 and from what I read I need to add
Pin 11 = V+
Pin 12 = V-
Pin 13 = CA+
Pin 14 = CGND
but I have no idea what wires that means? I have an;
RCA center pin
RCA shield pin
light +12
light ground
Can anyone help with the labels here?
Pin 11 = V+
Pin 12 = V-
Pin 13 = CA+
Pin 14 = CGND
RCA center pin
RCA shield pin
light +12
light ground
Check these posts in 4.3 Interior forum. The first helped me the most. Hope this helps.
Connect factory backup camera to aftermarket head unit
mtber
Sticky: Reverse Camera on 2009 to 2011 OEM Navigation Units - CONFIRMED!
pillpusher84
New Kenwood DNX771HD install in 2011 RAV4: No AM Reception
SteveV
Display Rear Camera on Factory Nav Screen
pillpusher84
Pin 11 = V+
Pin 12 = V-
Pin 13 = CA+
Pin 14 = CGND
RCA center pin
RCA shield pin
light +12
light ground
From what you've provided, it looks like you have them listed in the proper order. This should work:
Pin 11 = V+ RCA center pin (NTSC video positive)
Pin 12 = V- RCA shield pin (NTSC video ground)
Pin 13 = CA+ light +12 (camera power)
Pin 14 = CGND light ground (camera ground)
DO NOT tie the video ground and power ground together.
JuneBug
that is what I needed thx.
Oh a post mentioned something about adding a wire to the backup 12 sense line.
"You will need to insert a 12v+ signal onto pin 5 of the 5-pin connector (Connector E82 - Part # 90980-11909)"
I think my car already has that pin. I recall a VSS, PB, Revere connector. Do I need to do anything with my reverse sense pin or just hook up the 4 pins as mentioned? If I did the quoted would that not give my rear cam 24/7?
Discussion Starter · #5 · (Edited)
yeah when in rev. I do not have voltage on thes lines?
Though Pin 14 does have continuity to ground. So I think it is just a matter of getting the unit to sent +12 to the camera.
update:: I found a 12volt c-light adapter that put out 12 volts and applying to to the camera didn't help. So my guess is the unit is not bring up the RVC mode.
update:I checked the 5 pin connector and pin 5 does have 12+ going in to the unit when in revere. So what does i take to get the unit to show a camera input? On most cars it does not even check for video footage and shows a black screen in that case. This unit did show a reverse screen a long time ago (before I had the idea of putting in a cam) by accident but I never could recreate that.
update: I also pulled the radio and arched the + - leads in hopes to get it to hard reset. It did a full reboot but still no luck. Is there no eng. menu in these?
Discussion Starter · #7 · (Edited)
Ok got it, was a pin issue (pins didnt reach all the way in).
the +12 is showing 6 volts. So I did have to use another source. The 6 volts does not show a clear picture. Though since I'm mounting this near the backing lights cant I use that source of power?
