I been having starting problem this whole month and can't seem to figure it out.
This is from my car just right now. Can someone help me with the code please.
I can at least get you started. The continuous steady blinking means no error in those systems.
You have 41 EPS and 94 4WD codes. Hopefully someone else can decode them.
The power steering code of 41 is ECM communication error. The 4WD code 94 indicates Low Power Supply Voltage. The trouble areas are listed as
-Battery
-generator
-ECU-IG1
-Wire harness
-4WD control ECU
I would start by checking the battery.
Title changed since these aren't OBDII (emissions related) codes but rather those using the jumper method at the OBDII port.
As JuneBug says a weak battery can trigger all manner of errors, in particular Electric Power Steering ones since it's a heavy drain on the battery.
