canoes on the roof rack?
1328 Views 12 Replies 8 Participants Last post by  Axel10
Heavily contamplaiting buying a 16ft canoe for fishing. im not too worried about modifying the rack because im a pretty good welder but has anyone put a canoe or anything that long on the roof? would it be sketchy?
1 - 13 of 13 Posts
I am picking up my 13 foot sportspal on Sunday from the cabin and I got a couple of 2x4 that I am going to tie to the existing cross bars to make sure I have enough real estate to get the wide canoe on top, I think that the sportspal is 39 inch wide which is just about the same dimension as the rack base so the 48 inch 2x4's should work for me.
watching this thread and will let you know how I do.
Regards,
Crankster
they make good cross bars that help to tie the roof rack better for a solid square.
that would help when loading with one person.
best to lift it up on with two persons then tie down solid.
they like to sail when at 55+ mph!
Automotive parking light Wheel Automotive side marker light Car Vehicle
I recently put a 28 foot extension ladder up there for work, to give you an idea.
so whats that 14 feet?
Yes, that would be 14' non extended length. Your canoe would be about 2' longer.
I put the 13 foot sportspal on the roof rack and the gunnels were just a little bit wider then the top curve of the cross bar. It worked but next time I am going to put two 48 inch 2x4 tied to the cross bars to stick out 4 inches on each side beyond the rails to make loading, unloading, and final tie down easier.
For what it is worth, i used three rachet cargo straps with s hooks to go through the side rails of the roof rack. Went over the canoe, around the siderail, and then back over the top of the canoe again. I have found that if you go around the canoe under it, the unsupported strap makes a terrible vibration and noise such that over top twice is the way to go. 12 foot long ratchet straps were long enough. S hooks to fish them through the siderails.
I see a lot of cargo with two straps going down the road, be it canoes on top of vehicles, trailers, whatever. I always use three straps in case one strap fails for one reason or another. If a strap fails, i might get some vehicle damage from the flailing strap but my cargo is going to remain until I can get off the side of the road safely. In a two strap system, one strap fails and your cargo could fly off and kill somebody.
Regards,
Crankster
I also put a red flag on the back end of my canoe to make it more visible with the red color and motion
I don't think the issue is whether you can do it, it's more if it's legal. I know in New Zealand this is very illegal to have something sticking out this much. The laws obviously differ in the states, so I suggest that you look into that. I personally, would just buy a trailer, but up to you.
As long as you don't parachute the canoe it will be ok. The bracket sheer rating is well over the forces you'd experience with a canoe mounted, just keep the nose angled downward and tie a strap or 2 to the tow points under the front bumper.
Any suggestions - Need some help getting a canoe on top
I have a 2022 XSE Prime with the POI installed rails and cross bars, just hooked up a Thule Portage canoe carrier but even my smallest 14' Old Town canoe is too wide in the gunnel to fit at the positions that the cross bars are mounted, since the factory cross bars are too narrow -(they have a longer 'bracket' on each side where the cross bars fit into to, takes up 3 inches on each side so this narrows the usable cross bar width by perhaps 6 inches) the Thule blocks fit great on the cross bars themselves, but there is not enough room for the canoe - how far BACK can you slide the rear cross bar, ( so the narrower part of a canoe could fit) I have mine at the distance that it arrived from the dealer - or should I just forget this entirely, as Crankster mentioned, but I cant see how to strap a 2x4 to the cross bars a and return the Thule Portage ? If so, whats the best way to attach 2x4 to the rails?
thanks for any advice!
Bembel
Hi Brembel:
I got a long piece of 3/8 inch rope and put about 30 hitches (knots) wrapping the rope around the cross bar and the 2x4.
Four pieces of rope, two for each cross bar/2x4.
Then when the canoe is on the 2x4, my ratchet strap goes around the roof rails and over the canoe such that when tightened, they sandwich the 2x4 in-between the canoe and roof rails.
As I said before, I like to use three ratchet straps for safety in case one of the three straps fails, I still have two holding the canoe secure while I navigate to a safe place to correct the situation.
Regards,
Crankster
2
I've had great success using the OEM crossbars with the Malone Big Foot Pro canoe carrier. This summer we put approx. 1000 km carrying a 16 ft canoe the way it is setup in the pictures below. Unlike the previous Yakima gunwale brackets I used (on square Thule bars on previous SUV), the current combination is solid and absolutely did not move/shift or feel squirmy - to the contrary it felt as solid at the end of the journey as it did at the start. Highly recommend!
Tire Wheel Car Land vehicle Vehicle
Wheel Tire Car Land vehicle Vehicle
1 - 13 of 13 Posts
