1 - 2 of 2 Posts
I've removed the unit behind the HVAC panel. The unit has cables that run down to the blend door and elsewhere. There is also 5 small electrical leads that run into plug that is at the back of the AC button. I cannot work out how to detach this plug. It has some kind of plate that slots into stop it moving either in or out of the AC button "hole" that runs through to the panel at the front. I cannot move the plate in any direction, and pressing the little lever button on top doesn't allow me to pull it out. The pictures are here: https://goo.gl/photos/Sdq59VZaKdXG6STD9
Discussion Starter · #2 ·
I should add there are 2 little plastic latch looking things on the side, but they don't want to seem to move, and are probably part of the plug, as they move when I wiggle the plug.
1 - 2 of 2 Posts
