J
I was wondering if there was some sort of diagnostics program (that would possibly monitor car functions like speed etc...) that you could run on a laptop and hook up to your car to monitor your rav4's "stats" in real time? Anyone know of such a program? Thanks for any information...
-justinr
Toyota Rav4 1998
Well, it's not a Windows program for your laptop, but something like this - http://www.scangauge.com - might be an option. It's a small device that you plug into your OBDII port. It'll read and reset diagnostic codes as well as provide real-time information about fuel flow, fuel economy, miles to empty, max and avg. speed, throttle position, battery voltage, etc.
I just ordered one of these and plan to use it for monitoring fuel economy, real time and by trip, instead of having to do it by tank.
Davis Automotive makes the CarChip module that plugs into the OBDII interface and logs data -- you connect it to your computer by USB or Serial port. I haven't personally seen the software, but some of the data is supposed to be real-time -- not sure if you can connect it to your PC for real-time info. Especially good for troubleshooting.
Amazon usually has it on sale for much lower than retail.
Found this other software called the OBD-2 Scan Tool. I'm sure there's other hardware/software combos out there.
X
I had a Carchip for about a week. It does work really well, but you can't watch real time data with it. You plug it into the OBD port, log data while you're driving, then download into your computer. I have a Auterra scan tool that plugs into my Palm and it works great. www.auterraweb.com It supports almost all cars with OBDII from 96 on. Not the new CAN vehicles though. I love mine. It's really easy to use for monitoring O2 sensors, fuel trims, manifold pressure, timing, calculated load, etc. Plus, it supports Mac OS X for all of you Mac users.
It also has some other features that I haven't tried yet. Acceleration and horsepower tests are included in the software, but you need to know a lot of specifics about the RAV that I didn't know. Gear ratios, frontal area in sq ft, and drag coefficient.
Let me know if you have any questions about this one.
X
I was just on Auterra's website and downloaded the updated software for my scan tool, and now it says it does support CAN as well as the other OBDII formats. Now I should be able to use it on any OBDII car from 96 and on. Cool.
