Welcome! When you said that your RAV wouldn't start, does that mean that the starter motor wouldn't engage? Preliminarily the problem would appear to be with the battery but it should be load tested, not simply voltage tested (many auto parts stores will do that for free) in order to be certain. If after having the battery tested it passes the test, checking and if necessary cleaning the battery and battery cable connections would eliminate that as the cause.
