1 - 2 of 2 Posts
good, I have a problem with a 1az-fse 2004 toyota award engine .. this car has no power at the first start .. when the engine heats up the power improves .. it only does it in drive ..
the scanner gives me the codes p1653 scv motor circuit
, c1201 range of the brake booster sensor circuit and the famous pp0135 oxygen sensor bank 1
would you appreciate helping me better understand this engine. I do not see it every day is a direct injection to gasoline
I would clear the codes and remove the battery cables overnight to reset the Ecm . From what I can tell the C1201 P1653 code could be the result of the P0135 code . It can cause the vehicle to go into the limp mode if your car has ABS traction control system. It looks taking care of the P0135 code should fix the other two.
1 - 2 of 2 Posts
