Year and model of your RAV4 please.
2020 rav4 XLE.....automaticYear and model of your RAV4 please.
Or the cracked block recall?How many miles on your Rav? Was your car part of the fuel pump recall? There is a thread about the software update for the 2019 model year. What is your build date (upper right on the vin sticker)?
It’s a 2020 rav4, a little less than 20k milesHow many miles on your Rav? Was your car part of the fuel pump recall? There is a thread about the software update for the 2019 model year. What is your build date (upper right on the vin sticker)?
Thank you. I do not know how to post my videos. I have been having kick back issues when driving so my father was checking everything and he noticed way too much blow by when he opened the cap. He also used a stethoscope and some pistons (I believe what he said) sounded off.Post your videos where other can see and evaluate.
Also you refer to blow by when open the oil cap. Can you further eloborate?
Did you check to see if your RAV was impacted by the cracked block recall?Thank you guys, my father thinks it’s either a blown gasket or pistons. He is an old school certified mechanic. He said some small amount of air is normal but the amount coming out isn’t normal. I do not know how to add a video on here so you can see how much blow by I have.
I was just there for an oil change and they told me “there is no recall”. I feel like I’m being lied to and they are brushing under the rug. Was it for 2020 rav4?Did you check to see if your RAV was impacted by the cracked block recall?
WOW I just searched the recall and I had antifreeze leakage months ago and they told me that was normal. I told them it is absolutely NOT normal! I will attach a picture of that too.I was just there for an oil change and they told me “there is no recall”. I feel like I’m being lied to and they are brushing under the rug. Was it for 2020 rav4?
yes.I was just there for an oil change and they told me “there is no recall”. I feel like I’m being lied to and they are brushing under the rug. Was it for 2020 rav4?
A blown gasket - such as a head gasket - or a blown piston should throw a CEL on a modern engine - at minimum a rich or lean condition - likely some misfire as well. If you do have a problem with blow by it is more likely something along the lines of a burnt valve or stuck rings or whatever. It could also be a cracked block - per the other suggestions - and it wouldn't necessarily need to be in the recall - sometimes materials just fail.Thank you guys, my father thinks it’s either a blown gasket or pistons. He is an old school certified mechanic. He said some small amount of air is normal but the amount coming out isn’t normal. I do not know how to add a video on here so you can see how much blow by I have.
If you had a blown head gasket and coolant was leaking into the combustion chamber you would have billowing clouds of white smoke coming out of your exhaust pipes and most likely some liquid also. If you had a cracked or defective engine block casting the coolant would be going into your oil pan and you would see this on the dipstick as the fluid level rises up way above the maximum mark. If a head gasket or crack in the block was leaking externally outside the engine you would see huge puddles under the car and could see the coolant trickling out of the side of the engine from such external leak because it is under pressure when the engine is running. Did you have any of these conditions?Here is the coolant leak which was in January.
This seems like an exaggeration of the "cracked block" symptoms that Toyota publicly acknowledged.If you had a blown head gasket and coolant was leaking into the combustion chamber you would have billowing clouds of white smoke coming out of your exhaust pipes and most likely some liquid also. If you had a cracked or defective engine block casting the coolant would be going into your oil pan and you would see this on the dipstick as the fluid level rises up way above the maximum mark. If a head gasket or crack in the block was leaking externally outside the engine you would see huge puddles under the car and could see the coolant trickling out of the side of the engine from such external leak because it is under pressure when the engine is running. Did you have any of these conditions?
