So lately I've been trying to find Carbon Fiber parts for the 2008 Rav4 model. I just recently bought one and as I'm exploring the vehicle I can't help but notice the incredible weight of the hood and the trunk. I own the base model 4cyl FWD and the weight those poor little wheels in the front have to pull up hills is A LOT. I constantly struggle to gain traction and you can only imagine how it goes in the mud. Horrid. So I searched for CF parts to reduce total weight but I can NOT find ANYTHING at all! All in all I came across a company willing to make the parts but they need 50 customers purchasing each of the parts for $1000 each for them to begin manufacturing them. Would anyone be interested in such parts for their vehicle OR does anyone know where I can find CF hoods and trunk for our cars? Thank you ahead of time. Here is the company name and contact info if you have any questions for them:
Peter McKnight
AdvanCarbon.com
ChargeSpeedUSA.com
VersusTradingCo.com
P: +1 (310) 962-7887
Since 1994
[email protected]
Maybe you should look for better tires to help get better traction? Making your car lighter will not help traction and do the opposite.
Seems a bit high for the hood at least when VIS already makes one and you can buy it for $760. Listed for 2006-2007 but the Gen3 Rav4 hood (53301-0R020) didn't change design for all years 2006-2012
To be honest there are very few on here looking to spend that kind of $$$$ on anything for that little of return. There are probably other options out there to boost hp/tq, reduce unsprung weight or even just lighten the load on the current platform to get a better result.
Peter McKnight
AdvanCarbon.com
ChargeSpeedUSA.com
VersusTradingCo.com
Since 1994
[email protected]
You could smear Vaseline on your existing hood; lay down fiberglass to make an intermold; then use the inside of that to lay carbon fiber in a vacuum bag; and then just use hood pins or make a latch box. If you are the DIY type. That is how we made CF hoods in the mid 1990s for our cars when they were not commercially available. But I agree, this mod is just for fun, little or no real-world effect would be noticed.
Sounds like you bought the wrong vehicle for what you do. As already mentioned - reducing weight won't help with traction, especially with a fwd. Traction shouldn't be in issue unless your tires suck, you're towing, or have a ton of cargo in the back. You can (should) fix one of those easily - the other two scream AWD and/or V6.
If you're still bent on reducing weight - removing seats, hitches, and spare wheel is free. Lightweight wheels aren't free, but are more readily available than custom body panels.
I've been thinking about it and it does seem like $1000 could be invested better. I've already installed a tunning chip and run 91 octane on the car and the results are incredible. I appreciate the feed back and lesson.
