Manual or automatic? From what country?
Why do you want to manually lock and unlock the center-diff?
The stock system is usually easy to repair if it is not working.
But if you just want to create this mod and have an unlimited budget, then the answer is yes.
I've done the 3sgte engine swap :)
Already flies on the beach but diff lock will make it that little bit better!
The reason most people prefer the Toyota lock system is the repairs are usually in the top center part of the engine bay, making for a very easy repair. But if you need to get to the locking mechanism itself, then the first step is to remove the engine and transmission from the car.
