1 - 2 of 2 Posts
I have a 2008 rav4 Limited, 2.4 L, automatic 4x4; I need to replace the center support bearing, what is the trick to removing the drive shaft and replacing the center support bearing? I have the part in hand and car on jack stands, I don't understand how the prop shafts are connected inside the carrier bearing.
I can't answer your question but did move it to the correct forum where someone else likely will.
1 - 2 of 2 Posts
