Hi All, I had a a bad MAF sensor I replaced it but I still had the VSC TC and Cel light on. I did the pull fuse and jumper the ODB port trick to clear codes. All the codes clears and now the engine is running really rough and cuts off while idling. Anyone see this before?
Yes, the ECM has to re-learn all the parameters that were cleared out when you pulled the fuses. Drive it a little and it should smooth out.
Yes, Thank you that did the trick but the lights came back on and the code is back saying MAF. Any ideas? Is there more than one MAF? or could it be 02 sensor?
No, there is only one MAF sensor. Try unplugging the connector from the MAF and reconnecting it. Are there any other codes?
