1 - 2 of 2 Posts
Hi guys,
When I hit the brake pedal, either car running or not, after like 1cm pedal travel distance, I can hear and feel a click sound coming from the bottom. Like a switch or relay operated.
Do you guys have a similar experience please let me know, it's not obvious when have music on.
Thanks a lot.
Will
That is either the brake switch engaging as you press the brake or the relay that is triggered by the brake switch. Either way it is normal. As you'll notice the brake lights work even when the car is off, hence the relays engaging.
1 - 2 of 2 Posts
