Hello everyone and first of all thank you for this awesome forum.
Just a short description of myself:
I am from Germany and 29 years old. I will finish my masters in 2 month. As a reward I bought myself a pretty cheap rav4.1 1996 stick shifted with 140.000km to drive it all the way from Munich Germany to Cape Town SA.
When I bought the car it made a clonk noise while accelerating or engaging the clutch. So I looked under the car and saw that the rear differential was moving up and down. So I replaced the front and rear differential mounts. After that the clonk was a bit less metallic sounding but, there as still a clonk. So I asked the toyota dealership and they said my differential was bad. So I bought a differential from a 2.gen rav4 and put this one in. Still the same clonk. So I think it was not the diff.
The middle mount of the propeller shaft looks good and it is not moving a lot. Also the engine mounts have no visible cracks or anything I see tell just from looking at it. And since it is happening even if I am not using the clutch, just accelerating, I do not suspect the clutch, or am I wrong here?
Could it be my transfer case ?
Or transmission?
Can the engine mounts be bad without cracks? (I think maybe the left one is moving a bit too much)
Thanks in advance!
Best regards
T.
Or transmission?
Thanks in advance!
Best regards
T.
