1 - 8 of 8 Posts
Hi my 08 V6 Limited is throwing this code for H02 banki1 sen2 heater circuit low. I am supposed to drive about 200 miles each way Thursday, would it be ok to drive with the check engine, vsc, and 4wd lights on at interstate speeds? Thank you
Yes you can drive with those lights on...your 4 wheel drive won't work nor will your stability or traction control...
Frehley76;210te9521 said:
Thanks, that helps a lot. I am going to order one and give it a shot.
Once you find the Denso part number (Denso is OEM) you can check around for the best price. I got mine online at Walmart shipped to store (took 5 days to get it). I have the 2.5 engine and it only took me 20 mins to change.(dealer wanted 350.00 to do it) Make sure you spray lots of PB blaster or some penetrating oil on it and let it sit overnight. You might want to get a 02 sensor Socket to get the sensor off. Also make sure you put the anti seize paste on the threads on the new 02 sensor. Let us know how it goes !
1 - 8 of 8 Posts
