1 - 18 of 18 Posts
Here's a list of common maintenance parts that the 4.3 do-it-yourselfer might replace. Oil filter, air filter, cabin air filter, and wiper blades. All the Toyota OEM part numbers are listed as well as a few prices I've found online. Also some aftermarket part numbers are listed, and prices listed are from 2009. Might be a good idea to print this out and stick it in the glove box or console:
Toyota RAV4 4.3 Parts:
Oil filter element kit 3.5L V6 or 2.5L I4
04152-31090 or 04152-YZZA1 ($5.77) Brandsport.com
TRD PTR43-00082 ($11.77) Brandsport.com
Air filter element
17801-AD010 ($19.77) Brandsport.com
ACDelco A3104C ($10.46) Amazon.com
TRD PTR05-33070 ($69.77) Brandsport.com
Purolator A45650 ($14.59) Advance
Fram CA10169
STP SA10169 (12.59) Autozone
Wix 49172 ($14.23)
Cabin air filter
87139-YZZ08 ($22.77) Brandsport.com
HEPA 87139-07010
FRAM CF10285 Fresh Breeze
($14.86) Amazon
Purolator C35667 Pep Boys, Advance Auto ($11.99)
Hastings AF1334
Baldwin PA4327
Bosch P3502
Hengst E2945LI
Mann & Hummel CU1919
STP CAF1816P ($13.99) Autozone
Wix 24483 ($12.52) Amazon
Wiper blade rubber refill
Driver side 600mm (24") - 85214-50100 ($6.35) Brandsport.com
Passenger side 425mm (17") - 85214-04012 ($4.50) Brandsport.com
Rear 305mm (12") - 85214-31010 ($3.23) Brandsport.com ($1.92) 1st Toyota Parts
Wiper blade complete
Driver side refillable - 85222-24080 ($26.77) Brandsport.com
Driver side non-refillable - 85222-YZZ11 ($13.77) Brandsport.com
Passenger side refillable - 85212-35071 ($11.77) Brandsport.com
Passenger side non-refillable - 85212-YZZ03 ($9.77) Brandsport.com
Rear window refillable - 85242-42030 Brandsport.com ($7.77)
PROLINE PRV122 ($11.99) Pep Boys
Thanks! Maybe this can be made into a sticky, and include common mods or links to threads such as the homelink addition or the steering wheel control button threads?
I have updated the parts list in the first post and added a few things. Hope this helps!
Wow haven't posted on R4W in awhile, since I sold mine :(
I have a 09 Corolla XRS now, and it uses some of the same air filters as the current RAV4. I can give these numbers below as I got the aFe dry filter for my XRS.
Drop-In Filters:
K&N 33-2326
aFe 30-10151 Pro 5R
aFe 31-10151 Pro Dry S
Thanks! The guy at Autozone told me I had to go to the Toyota dealership to replace the rear wiper. He said the rubber refill cannot be replaced. Bah. :/
4 months ago I bought a cabin filter (Purolator A45650 from Advance Auto). I just replaced it with a Denso from Rock Auto for 18.05 total. Price included a 5 percent discount code. IMO there is a big quality difference in these filters.
Check out my rear wiper story in Exterior. The rear cant be refilled but they are non standard from the front hook type. Rears are:
TYPE A ROC LOC 2
Discussion Starter · #10 ·
TYPE A ROC LOC 2
NONSENSE! I just refilled all 3 wiper blades a couple of days ago. The rear wiper blade insert is Toyota part number 85214-31010 and was around $4 from my local dealer. Popped out the wiper arm and replaced the insert on my kitchen table.
Here's a list of common maintenance parts that the 4.3 do-it-yourselfer might replace. Oil filter, air filter, cabin air filter, and wiper blades. All the Toyota OEM part numbers are listed as well as a few prices I've found online. Also some aftermarket part numbers are listed. Might be a good idea to print this out and stick it in the glove box or console:
Air filter element
17801-31120 ($19.77) Brandsport.com
Fram CA10169
Wix 49172 ($14.23)
Cabin air filter
HEPA 87139-07010
Fram CF10285
Hastings AF1334
Baldwin PA4327
Bosch P3502
Hengst E2945LI
Driver side 600mm - 85214-YZZD5 ($6.35) Brandsport.com
Passenger side 425mm - 85214-04012 ($4.50) Brandsport.com
Rear - 85214-31010 ($3.23) Brandsport.com ($1.92) 1st Toyota Parts
Would many of these parts fit the 4.4 as well? Perhaps a sticky could be added to the 4.4 threads, as I would have never seen this post, but was curious about previous generations of the RAV4, and came here to check it out!
Thanks y'all. This info is a goldmine for me. yotatech for the 4X4 and rav4world for the RAV4. Thanks again and keep up the great work it is very much appreciated.
Air filter element
Fram CA10169
Wix 49172 ($14.23)
Cabin air filter
HEPA 87139-07010
FRAM CF10285 Fresh Breeze ($14.86) Amazon
Hastings AF1334
Baldwin PA4327
Bosch P3502
Hengst E2945LI
Hey rav4pro! Can you tell us the big differences that you have noticed between the two filters? Which one is better, etc.?
2012 Rav4 2.5L I4 4WD base + value package
Thanks, this is very helpful! The first post could use an update since some part numbers have been replaced with new ones. I was just shopping for wiper blades and see that:
has been replaced by 85222-0R040
has been replaced by 85212-0R040
And for the wiper blade refills:
seems pegged to only the 2008 year, and 2009+ refill is listed as 85214-05110. They may be identical, but I ordered the newer part number.
Thanks also to the site for clueing me in to the inexpensive Toyota wiper blade refills, which seem a much better solution (and less wasteful) than continually replacing expensive third-party blades. But first I need to get OEM blades back on in order to start using the refills . . . When I checked, McGeorge Toyota and Boch Toyota had the best prices for blades, but only Boch would ship the refills. Of course, it might be easier to pick them up locally.
1 - 18 of 18 Posts
