Common replacement parts list with Toyota part numbers
55K views 18 replies 14 participants last post by  JuneBug
#1 · (Edited)
Here's a list of common maintenance parts that the 4.3 do-it-yourselfer might replace. Oil filter, air filter, cabin air filter, and wiper blades. All the Toyota OEM part numbers are listed as well as a few prices I've found online. Also some aftermarket part numbers are listed, and prices listed are from 2009. Might be a good idea to print this out and stick it in the glove box or console:
Toyota RAV4 4.3 Parts:
Oil filter element kit 3.5L V6 or 2.5L I4
04152-31090 or 04152-YZZA1 ($5.77) Brandsport.com
TRD PTR43-00082 ($11.77) Brandsport.com
Air filter element
17801-AD010 ($19.77) Brandsport.com
ACDelco A3104C ($10.46) Amazon.com
TRD PTR05-33070 ($69.77) Brandsport.com
Purolator A45650 ($14.59) Advance
Fram CA10169
STP SA10169 (12.59) Autozone
Wix 49172 ($14.23)
Cabin air filter
87139-YZZ08 ($22.77) Brandsport.com
HEPA 87139-07010
FRAM CF10285 Fresh Breeze ($14.86) Amazon
Purolator C35667 Pep Boys, Advance Auto ($11.99)
Hastings AF1334
Baldwin PA4327
Bosch P3502
Hengst E2945LI
Mann & Hummel CU1919
STP CAF1816P ($13.99) Autozone
Wix 24483 ($12.52) Amazon
Wiper blade rubber refill
Driver side 600mm (24") - 85214-50100 ($6.35) Brandsport.com
Passenger side 425mm (17") - 85214-04012 ($4.50) Brandsport.com
Rear 305mm (12") - 85214-05110 ($3.23) Brandsport.com ($1.92) 1st Toyota Parts
Wiper blade complete
Driver side refillable - 85222-0R040 ($26.77) Brandsport.com
Driver side non-refillable - 85222-YZZ11 ($13.77) Brandsport.com
Passenger side refillable - 85212-0R040 ($11.77) Brandsport.com
Passenger side non-refillable - 85212-YZZ03 ($9.77) Brandsport.com
Rear window refillable - 85242-42030 Brandsport.com ($7.77)
PROLINE PRV122 ($11.99) Pep Boys
#2 ·
Thanks! Maybe this can be made into a sticky, and include common mods or links to threads such as the homelink addition or the steering wheel control button threads?
I have updated the parts list in the first post and added a few things. Hope this helps!
#5 ·
Wow haven't posted on R4W in awhile, since I sold mine :(
I have a 09 Corolla XRS now, and it uses some of the same air filters as the current RAV4. I can give these numbers below as I got the aFe dry filter for my XRS.
Drop-In Filters:
K&N 33-2326
aFe 30-10151 Pro 5R
aFe 31-10151 Pro Dry S
#10 ·
NONSENSE! I just refilled all 3 wiper blades a couple of days ago. The rear wiper blade insert is Toyota part number 85214-31010 and was around $4 from my local dealer. Popped out the wiper arm and replaced the insert on my kitchen table.
#11 ·
Here's a list of common maintenance parts that the 4.3 do-it-yourselfer might replace. Oil filter, air filter, cabin air filter, and wiper blades. All the Toyota OEM part numbers are listed as well as a few prices I've found online. Also some aftermarket part numbers are listed. Might be a good idea to print this out and stick it in the glove box or console:
Air filter element
17801-31120 ($19.77) Brandsport.com
Fram CA10169
Wix 49172 ($14.23)
Cabin air filter
HEPA 87139-07010
Fram CF10285
Hastings AF1334
Baldwin PA4327
Bosch P3502
Hengst E2945LI
Driver side 600mm - 85214-YZZD5 ($6.35) Brandsport.com
Passenger side 425mm - 85214-04012 ($4.50) Brandsport.com
Rear - 85214-31010 ($3.23) Brandsport.com ($1.92) 1st Toyota Parts
Driver side refillable - 85222-24080 ($26.77) Brandsport.com
Passenger side refillable - 85212-35071 ($11.77) Brandsport.com
Would many of these parts fit the 4.4 as well? Perhaps a sticky could be added to the 4.4 threads, as I would have never seen this post, but was curious about previous generations of the RAV4, and came here to check it out!
#15 ·
Air filter element
Fram CA10169
Wix 49172 ($14.23)
Cabin air filter
HEPA 87139-07010
Hastings AF1334
Baldwin PA4327
Bosch P3502
Hengst E2945LI
Rear 305mm (12") - 85214-31010 ($3.23) Brandsport.com ($1.92) 1st Toyota Parts
#18 ·
Thanks, this is very helpful! The first post could use an update since some part numbers have been replaced with new ones. I was just shopping for wiper blades and see that:
has been replaced by 85222-0R040
has been replaced by 85212-0R040
And for the wiper blade refills:
seems pegged to only the 2008 year, and 2009+ refill is listed as 85214-05110. They may be identical, but I ordered the newer part number.
Thanks also to the site for clueing me in to the inexpensive Toyota wiper blade refills, which seem a much better solution (and less wasteful) than continually replacing expensive third-party blades. But first I need to get OEM blades back on in order to start using the refills . . . When I checked, McGeorge Toyota and Boch Toyota had the best prices for blades, but only Boch would ship the refills. Of course, it might be easier to pick them up locally.
#19 ·
Thanks! I have updated the part numbers.
