Hi guys,
New member here who just inherited a 1998 4DR 2WD and it's such an honest car .. 115000 miles and still kicks pretty strong.
Went to do a tune up and when I got to the cooling system .. I just found rust ... everywhere. In the overflow bottle and on the cap and filler neck of the radiator itself. Best guess is this system wasn't well looked after. I found this forum and have been perusing for a week now for some info.
Some questions:
1) Too much rust in the radiator .. ordered a new rad just to be safe. I literally found 1 video with some Aussie who managed to take the rad out without discharging the AC. Any other success stories like this? Video did not show him actually putting a new rad back .. just removal. Another tutorial showed a guy actually cutting off the cross member support to make room. Probably won't do that.
2) In the meantime, I wanted to flush and fill, flush and fill, flush and fill with a rad cleaner. which heater hose is the inlet/outlet when looking towards the firewall? left or right? Saw the sticky where it pointed the heater hoses, but didnt denote which was inlet or outlet.
3) thermostat! 50/50 says you dont need to remove the alternator to get at it, but I see where problems aros with the lower housing bolt because of the oil filter and AC onnection. I think I can get it without alternator removal (but obviously oil filter neds to be removed), but what kind of tool did you guys use? The open end on my wrench seems like it'll round it off and i have those nifty ratchet end on the other side so the wall is too thick to fit around the nut.
I like searching for the info and no stranger to forums, but ive been at it for days with not a conclusive answer to these things.
Some questions:
