Corroded high voltage cable in RAV4 hybrid
14515 Views 141 Replies 40 Participants Last post by  Salvinorin A
I took my 2020 RAV4 hybrid to the dealer for checking the corroded cable problem. The car didn’t show any messages on the screen.
the technician came back in 45 minutes telling me there is lots of corrosion of the cable, the car failed their tests. Cable need change. They told me they will order parts from Toyota which will take couple of weeks. Toyota will cover all. Car is out of 3 years warranty.
It is really unfortunate that a 3 year old car has a significant problem like this. Toyota should have designed this cable connection away from snow and salt !
is the new design / replacement better? Will the problem happen again in 3 years?
Reactions: 4
1 - 20 of 142 Posts
Hmmm. The extended warranty for that cable does not currently apply to the 2023 model. So does that mean that cables that are replaced for the 2019-2022 models are also excluded from the extended warranty? And if it fails a second time, are you screwed?
It still remains to be seen how the new cable will hold up.
I'm going to go in get mine checked next week, 2020 as well. I have the AM static problem that I can replicate following the steps on the NHTSA doc posted in the now locked corrosion thread. The TSB (for US), shows a cutout on page 8 and that seems to be that for the fix.
I'm 6k KM's over my warranty, so we'll see what they say. A reddit user helped provide me a warranty code to argue the dealer if some face a wall - look up the Warranty Extension Program or (WEP65) specifically. Seeing as we have no official notice in hand from Toyota corpo.
You should both ask if the replacement cable is also covered by the 8-year warranty.
From what I'm reading, due to part shortages, Toyota has to prioritize from 'undrivable' to 'driveable with symptoms'. A user who claims to work for a CA dealer over on reddit when I asked says the local dealer can not order the HV harness no matter what. They have to be released by Toyota Canada, and there is a backlog. When I went to the dealer yesterday to get some oil they confirmed the harness has a stop sale on their end meaning they can't order it. Either way a new cable would be ideal for me since I have radio static that is beyond bad...
Understood, but ask them if the replacement cable will also be covered by WEP65. So should it also fail in 3 years, will you be covered or out of luck.
Reactions: 1
Car Care Nut seems to think that by switching the orientation of MGR and by adding the protective plastic cover to the underside of the car directly above the MGR cable that this could avert the corrosion issue. See this video starting at 8:50 where he has a RAV4 hybrid up in the air:
I'm just curious for anyone who has had this issue if they had the protective cover. I am looking at getting a hybrid RAV in the future, but I live down a dirt road in the mountains with snow on the ground from December until at least April. The Adventure looks better and better to me.
Reactions: 1
Toyota has extended the warranty for the 2019-2022 models, which is a good thing. The design is flawed beyond stupid.
I had a chance to examine a failed one the other day. From my perspective there are two causes of failure ( both of which present with the same two fault codes), the first is in the design of the lower male portion of the connector on the motor. Which is completely encased by a plastic housing. Water,small sand/salt can easily infiltrate this split plastic housing and then be sandwiched inside where the radio frequency shield is and of course the HV cables.
The second is the infiltration into the actual aluminium hub of the female portion of the connector.
In the first case of the male portion of the connector, it appeared to have experienced corrosion/freezing of water. In the example I saw the male aluminium case had actually cracked from freezing, and the plastic housing was bulged due to dirt, freezing and corrosion.
While I have not seen examples of the female portion failing, I have seen a video of it, in the other thread that is now locked.
I did order a 2022 Rav, but due to production limits I have the 23 model now. I do not know if there is a real fix yet to the new modified cable. The techs I spoke to are not sure, since the only difference in appearance is the new cable has a cut out on the plastic cover on the male portion of the connector.
When I put on my "thinking hat", I can see how the cut out may help to eliminate the issue of the male connector building up with water/dirt and salt, but the issue of migration of salt/water into the female housing could occur. I do think the issue on the female connection point is one of poor materials of the internal rubber gasket.
The connector I saw, even though it was the male end that failed, the rubber on the female connector was shrunken and cracked. It has slipped right off the male portion and was kind of just sitting inside the female housing. I hope on the replacement cable, they addressed this rubber gasket. Perhaps the original was of poor quality, and didn't have the same expansion/contraction rates as the aluminium housing it is seated in?
Time will tell if this a fix, or if failures will keep occurring and the warranty extension will also happen on the 2023 models as well.
I should also add,that the replacement is of the entire harness components. Including the harness above that connects into the electric motor. But given the past life time of the original cable, if there was not a major redesign , that only gives the average snow/salt/winter drivers two years or so.
Just spoke to my mechanic (independent shop) that replaced the HV cable on a Rav 4 Hybrid with 120.000 miles. Toyota USA did not cover this repair.
Toyota USA would not ship the cable, that owner had to pay for, until shop showed picture of the fault codes, and a picture of the corroded cable.
job cost the owner $5000 US.
Reactions: 2
I live in Canada, Saskatchewan where lots snow Nov till May. I keep the car in garage where temp is 5 c in winter. Outside in winter could reach -40. I don’t know if melting snow makes this problem happens faster. Yes, they use salt in the area where I live !
Reactions: 1
Northern Ontario here, they use raw salt, two types of salt sprays and 2% salt/sand mixes. Depending upon what type of surface treatments are needed. They may even be trying beat juice in a few spots as well.
Lots of cold and winter is 10 months long, with 2 months of poor sledding ....
Reactions: 1
Has Toyota issued a public statement saying they were extending the warranties of all 2019-2022 RAV4 Hybrids specifically for the H/V cable issue? If so could you post a link for that statement from Toyota. Thanks!
To comment on the above RE weather conditions. I’m southern Ontario, I noticed this similar AM static ‘during’ a nasty snow storm we had start of Feb. didn’t pay any mind because I thought the storm was messing with the signal. The car was then garaged for 1 week (work trip) with a chance to dry off and I forgot about it. It was a rainy 3 weeks when I came back and had no problem during any of the rain drives.
Flash forward to another snow storm recently, and then garaged for 2 weeks (work trip), came home and drove on a blue bird day yesterday with the same intense AM static.
Both times before garaging the car I went through a car wash with underbody wash to clear the salt. My 2 cents is the cable operates better when flooded, but when dry and I guess crusty after drying is when the issue shows.
Reactions: 1
Melting certainly accelerate the process... Does your Rav has a shield underneath it? I believe early ones didn't have one.
as far as certain vehicles
CUSTOMER SUPPORT PROGRAM 22TE09
Certain 2019 – 2022 Model Year Rav4 HV (AWD Only)
Coverage for HV Floor Under Wire Harness and Rear Traction Motor Cable Corrosion
Model / Years Production Period Approximate Total Vehicles
2019 – 2022 Rav4 HV AWD Mid-August 2018 – Mid-November 2022 437,140
Covered Vehicles
There are approximately 473,100 vehicles covered by this Customer Support Program.
There are 3,400 vehicles in Puerto Rico involved in this Customer Support Program.
Customers with additional questions or concerns are asked to please contact the Toyota Brand Engagement Center (1-888-270-9371) - Monday through Friday, 8:00 am to 8:00 pm, Saturday 9:00 am to 7:00 pm Eastern Time.
This is for Canada, not sure it applies in the US.
Reactions: 1
Mine's 10 days old....never had it up on a hoist yet, so I don't know for sure, but as far as I understand they started putting the "little" pan on in 2020.
Mine's 3 months old, so I guess we have couple years to find out how effective is that shield and an open design connector.
Well verticals with the shield have had corrosion issues too. I'm not trying to be pessimistic here, just it's hard to engineer a cure for a poor design.
Reactions: 1
"Q6: What if an owner HAS NOT experienced this condition but would like to have the repair completed?
A6: This Customer Support Program only applies to vehicles that have exhibited and been diagnosed by an authorized Toyota dealer with the condition described above.
If an owner has not experienced the condition, he/she is asked to tear off the sheet included in the owner letter and insert it into the Owner’s Warranty Information Booklet for future reference.
"Q8: What if I previously paid for repairs related to this Customer Support Program?
A8: Reimbursement consideration instructions will be provided in the owner letter.
Q9: How does Toyota obtain my mailing information?
A9: Toyota uses an industry provider who works with each state’s Department of Motor Vehicles (DMV) to receive registration or title information, based upon the DMV records.
Please make sure your registration or title information is correct.
Q10: What if I have additional question'
Should answer most of the questions....
regarding parts
Priority
process
For those who've had the work done at their expense, this is also address.
Reactions: 2
Thanks to @Fuzzy19 and @windwalker099 for posting that information. I feel better now that there is some type of acknowledgement from Toyota on the H/V cable issue.
Reactions: 2
1 - 20 of 142 Posts
