1 - 15 of 15 Posts
The last bolt can't go in because the hole is too small by 1/8." If I start with that hole, bolt won't go in on the other side. Looks like other people had similar issues and was wondering how you resolved it. Uhaul employee suggested reaming the hole. I have a 12' RAV4 and bought part # 13149.
Did you tighten then as you go. I would start off with engaging only a couple of threads per hole and getting them all in. Then tighten each a little at a time till they are all in. If that won't work, then drill out the holes a little. What size are they now?
Yup, I try to evenly distribute the torque for such jobs. Curt sent a dimension sheet to check if the hitch was bent... I guess I'll do some measuring tonight.
My Curt hitch arrived with one side bent - like it had rolled off the end of a shipping belt onto a concrete floor. I had to straighten it out using a 3-ton floor jack and a length of 4x4 wood.
just looked on line and it seems that the curt is very popular. At least the market is flooded with them.
I wonder how low profile they are compared to the OEM toyota one. I doubt that toyota makes hitches though. I wonder who is their supplier.
Here's the OEM hitch on mine (ignore the red circles):
In this one, you can see it's just barely below the bracket (jack point?) hanging down, on the right side of the photo (I can't imagine any hitch being higher due to that bracket):
You may find more useful photos at R4W member John Davies' legendary OEM hitch page:
RAV4 Hitch
Discussion Starter · #15 ·
The replaced hitch installed just fine without any issues.
When I cranked the engine the first time, it died on me instantly. But fired up the second time and was fine, whew!
1 - 15 of 15 Posts
