Dealer repeatedly overfilled oil level
2318 28
I just completed my second 10,000 mile Toyota dealer service. On both services I found my dipstick level was 1/2" above the full mark on the dipstick. I returned the vehicle both times and requested that the level be corrected. The first time it was returned to me with the level exactly on the full mark. The second time I was told it was corrected, but later I discovered it was not. That service occurred last week. Frustrated I decided to do it myself, so I drained 1/2 quart and found the level to be just a hair above the full mark. I then wrote an email to the service manger explaining what happened. The reply I received basically told me I was being nit-picky and that the oil level being overfull is not an issue. Is he right? I was always told that the oil level should never be much above the full mark. I asked this question; "If your service department added the specified amount of oil why would it be 1/2 quart over?" I got no answer. Doesn't the filter hold about 1/2 quart? Is it possible they didn't bother changing the filter? Feedback would be appreciated. Thanks.
Status
Not open for further replies.
21 - 29 of 29 Posts
Hey, even dropouts need a job.
I know people who decide not to work, even if educated.
If not for the auto-industry, where else to you think high school kids or dropouts work?
Yes, I'm being sarcastic but I will be if we keep suggesting the employees are uneducated.
They may not be the proper person to change oil, however they should also be taught by the senior staff of the correct procedure.
If an oil change tech at a dealership does not know the proper procedure then it is fault of the service manager for not training the tech.
If the tech is instructed to add 5 quarts of oil to a vehicle requiring 4.5, then it is not at all on the tech. They have done as instructed. If they program the filler to go with 4.5 quarts and there is an engine failure later that week, it is the techs fault and will be fired for using his brain and doing it 'right'.
2022 Lunar Rock XLE Premium J-VIN
Anyone in the service department should know where the oil is supposed to be on the dipstick. They see these cars all day long. They see these cars brand new as delivered from the factory.
My RAV4 was delivered brand new with the oil level right on the money. Not a little over, not a little under.
When I change my own oil, to get the oil level to be exactly at the full mark, like it was when it was made at the factory, it takes 4.5 quarts.
NC '19 Rav4 Hybrid Limited, Entune 3.0, Adaptive Headlights, Advanced Technology Package
While certainly you want to leave time for all the old oil to drain out before filling, I believe the 5 minutes wait time is to allow the new oil to drain down to the oil pan so that an accurate reading can take place,
I started a previous thread about my RAV 4 Hybrid being overfilled with oil, after the 10,000 mile Toyota service.
Oil level on the dipstick was a 1/4 inch over upper mark, when cold. Motor oil warm, level was 1/2 inch over upper dipstick mark.
My dealer, where the car was purchased (a 2 hour drive) didn't really seem to care, even though they did the oil service.
I don't have any jacks, so I went to a closer dealer and paid $23 to get the oil level drained down. I spoke to the mechanic who did the work, and he said he drained 1/2 a quart of excess oil.
Even now , with a cold engine, oil level is right at the upper mark on dipstick.
Sure, a little overfilled won’t kill your engine, but why not just put the right amount in?
The right amount is somewhere between the minimum normal and maximum normal oil level marks, but everyone acts like you have to make sure the oil levels is at the maximum normal mark, which is very difficult to achieve with precision. It is best to target the half way mark between low and high for when both engine and oil are cold. That way there is enough headroom to account for oil/engine expansion as the engine and oil warm up, not 100% leveled parking surface, and/or oil dilution.
Reactions: Doodoo
In my experience 4.5 quarts is actually a bit much. You are supposed to check the level after the oil and engine are fully warmed up and at least 5 minutes after shutting off the engine. That's 30 to 45 minutes of driving. It takes a long time for both oil and engine to be fully warmed up. We are not talking about the coolant temperature. Even so, I leave some room for potential oil dilution.
I’ve been changing my own oil for almost 30 years and worked at Jiffy Lube in high school and college.
Let the engine sit for a few minutes after it’s warmed up and check it. I know that.
It absolutely does not take 30-45 minutes of driving for the oil to reach operating temperature.
In my experience, 4.5 quarts is perfect.
2021 XSE Hybrid, Blizzard Pearl
after draining the oil wait 5 mins start the car for 5-10 secs to clear out the extra oil then pour oil to the mark start the car up again for about 1 min then check were the oil is done, really isn't that hard and its more about taking pride in what you do no matter how small or big the task is at the sametime i get it if the dealer are using filler machines that are only designed to shoot full on quarts in and no half way mark.
2021 RAV4 Prime XSE in Magnetic Gray
Mods, can we shut this down? Once again, an oil thread has devolved into child-like behavior. I don't know what it is with you people/this forum and being unspeakably passionate about oil change procedures.
Agreed. I hadn't been following this thread but like many others once a simple subject goes on too long it runs off the road into a ditch. Closed! And will be pruned.
21 - 29 of 29 Posts
Status
