Dealer says high voltage cable needs replacing
12K views 106 replies 35 participants last post by  CoffeeBear
Upstate NY. Very credible diagnosis. No harm. I'd ask for updated components and a discount because of the poor design for a 4WD/AWD car and a common problem that should have been anticipated by the designers.
This was a known issue years ago. There is an extended warranty on the cable of 8 years or 100,000 miles (22TE09). When Toyota discovers a problem like this, they have been good at giving out extended warranties.
What is the breakdown for parts/Labour?
The T-SB lists the part numbers for the cable and a few miscellaneous parts that are needed. Then you can look up the price for the parts on the Toyota parts web site.
You would have thought that corporate would had added it to items for dealers to review basically based on the model and year of the vehicle since its their engineering. I have come to the conclusion that the dealership wants to keep it simple it took them two days to get my car from their lot into the garage
I have a folder where I keep all the Toyota service bulletins, customer support programs, and tech tips that apply to my RAV4. I have probably a hundred of them by now. No way can a dealer be expected to know about every thing that the factory has said should be looked out for and inspected on all the cars that come in for service.
Screw up the high voltage cable replacement and you will be on the fast track to sitting on a cloud, playing a harp beyond the pearly gates.
If you are lucky enough to go in that direction.
At one time I think the cost difference between the gas and electric version of the rav4 was $1,500. This year looked it was $3,000. That is the entire hybrid system:
  • the electric motors
  • the expensive hybrid battery pack
  • the inverter and coolant system
  • the hybrid cable
The transmission in a non-hybrid Toyota is an amazingly complex device compared to the simplicity of the PSD in the hybrids. That eight speed has to cost a lot more to make than the PSD.
