DeLand is selling them on Ebay.
It's fairly well made, thicker than the small protector that came on it, made of material similar to the mudguards.
Install was as simple as removing the 4 push pins, cleaning the bumper, then removing the tape backing, then carefully align the 4 holes for the push pins and setting it in place. It took more time to remove the tape backing than anything else!! The push pins just require a flat blade screwdriver to pop the pin up, then remove the whole fastener. The protector has several strips of pressure sensitive foam tape to stick it to the bumper.
I think the roll over at the bumper edge is good, less paint to get scratched, I like it!!
Tim
