No problem 415, glad the protector worked out. What is your issue with the antenna? What length? I have the 9" and seem to be fine.415 said:Well the replacement antenna was a bust , but the bumper protector from DeLand Toyota was a great successinstalation was a breeze and it looks great ! :thumbs_up: Thanks Janos
I also bought the same 9" from brandsport , it worked great everywhere but in the town I live in ( I live near a local airport ) . I work in another county and reception was great there also . I still have it and put it up for sale at $10 . If you know anyone PM me . I figure if your gonna try it you will only lose half the amount if it doesn't do well in your area . JohnJanos said:No problem 415, glad the protector worked out. What is your issue with the antenna? What length? I have the 9" and seem to be fine.415 said:Well the replacement antenna was a bust , but the bumper protector from DeLand Toyota was a great successinstalation was a breeze and it looks great ! :thumbs_up: Thanks Janos
garfieldgurl said:errr.. pics? :?![]()
Nope, just on the top surface on mine (which came with the tape already attached)...DmcGman said:Do you hvae the two sided tape on the overhang edge of the protector also?
Mine had ~1/2" thick foam in segments covering 60-70% of the perimeter of the op portion. It was about 1" from the edge. Hope that helps. But, if you bought it from Deland, I would first talk to them before I jury-rigged it.DmcGman said:I wonder why mine didnt have tape on it :-( Anyway I guess maybe 5 strips of tape in between the grooves on the top would be enough to hold it securely? Did yours have foam type double sided tape or regular two sided tape?
It is regular two sided tape. Janos' album has a nice picture of the underside of the bumpter protector. http://rav4world.com/forums/album_pic.php?pic_id=1354DmcGman said:I wonder why mine didnt have tape on it :-( Anyway I guess maybe 5 strips of tape in between the grooves on the top would be enough to hold it securely? Did yours have foam type double sided tape or regular two sided tape?
