1 - 14 of 14 Posts
Hey all, new RAV 4.1 owner and general car noob here
I just got my rav back from the shop (transmission fluid flush) and thought it would be a good idea to test everything out, including the center differential lock. Not knowing how the center differential lock works, and its proper applications, I did a brief drive around my neighborhood with it on to see if I could tell the difference in handling/steering (I learned later that this is a huge no-no).
I couldn't disengage the lock immediately, so I searched the forums for a solution and learned that you have to reverse the car to disengage it. I also learned that I might have ruined my differential lock.
So I looked under the car to see if anything was bent, and it looks alright. I didn't exceed 15-20 mph while driving with it on, but I did make some tight turns. It was probably less 3-5 minutes of driving with it on.
Guys, did I destroy my new beloved car pls halp
If your lock still works (on/off), all should be OK.
Really? I should have noted it's a 1996 2 Door. To switch it off, I had to reverse about 20-30 feet. Is that normal?
That's what I have to do to be sure my F-250 4X4 unlocks.
I'm starting to think it might not have even locked - the steering didn't feel decidedly different. It did beep when I had it locked and stopped beeping after I unlocked it, but I didn't really notice any other indicators. Is there a surefire way to safely determine if it's working properly?
Mash the gas on grass. If you can spin any tires it isn't working.
I have to reverse mine several feet in a straight line to unlock it.
eodgator, is there a consistent way to tell if yours is engaged?
Edit: I actually just went out and tested mine. I turned it on and back off, one single quick beep to let me know it had unlocked. Turned it back on, inched forward a few feet, and turned it off again, and that time it beeped a few more times before unlocking. I guess that means its fine and not damaged?
Discussion Starter · #10 ·
What did they charge for the trans flush samlo?
Like $80 USD, I just took it to my local jiffylube because I had coupons. Ran muuuch smoother after though and they looked over the underside of the car for me and topped off the oil too
If your lock works, you will feel ''drivetrain binding'' when doing a tight turn. If it's not locking, it will turn very smoothly (as normal).
Discussion Starter · #12 ·
Sorry if this is a dumb question - can I carefully test the lock like that on pavement without damaging it or the drive train? Right now if I engage/disengage it, I can hear the engine rev slightly to power the vacuum to turn it on or off.
if it is messed up, what are my first steps towards diagnosing/fixing it?
Most likely you damaged nothing. Find a slippery surface (it doesn't need to be ice, a gravel road will do) and, as already suggested, stop, turn the wheel all the way and accelerate for 4-5 meters. Then, do the same maneuver with the centre differential lock on. You should feel the steering wheel heavier.
I made the same mistake (only much worse) in my early days of driving the Rav. I accidentally pushed the diff lock switch instead of the hazard lights switch to turn off my flashers. Then drove for 10-15 km on pavement wondering if I had a power-steering failure. Due to my seating position, the indicator on the instrument cluster was obscured by the steering wheel. When I realized what was going on, I was devastated. Fortunately, from then on (70000 km later), I haven't noticed any issues with the drivetrain or the diff lock function.
That being said, I do NOT condone driving on tarmac roads with centre differential lock on.
More food for thought:
http://www.rav4world.com/forums/83-4-1-general/249825-lock-diff-awd.html
http://www.rav4world.com/forums/85-4-1-faults-fixes/186810-4wheel-drive-beeping.html
http://www.rav4world.com/forums/94-...245433-central-disconnect-wont-disengage.html
Discussion Starter · #14 ·
Hey Mick, thanks, that definitely put me at ease regarding the center differential lock! I'll give it a test this week.
1 - 14 of 14 Posts
