I recently purchased a used 2006 4wd, i4, base model RAV4. I discovered that I need to change out most of the fluids as they haven't been changed in the vehicles 105k mile life (as well as some other general maintenance). Since I like to research the jobs before I do any vehicle work, I've compiled quite the list of threads and YouTube videos that will help me, and will hopefully help you as well. I want to mention that I didn't create any of these DIY's, I'm just putting them in a central location. Hopefully this will help out the next person who needs to hit the ground running with their RAV!
Automatic Transmission Fluid Change:
http://www.rav4world.com/forums/99-4-3-mechanical/249777-automatic-transmission-weakness-fluids.html
https://r56hs.com/2016/02/22/2011-rav4-v6-awd-automatic-transmission-flush/
Transfer Case Fluid Change:
http://www.rav4world.com/forums/99-4-3-mechanical/235450-transfer-case-fluid-change-tips.html
http://www.rav4world.com/forums/99-4-3-mechanical/80866-transfer-case-differential-oil-change.html
http://www.rav4world.com/forums/99-...ial-transfer-case-gear-lube-3.html#post921385
Rear Differential Fluid Change:
http://www.rav4world.com/forums/99-...ial-transfer-case-gear-lube-3.html#post921323
Engine Coolant Change:
http://www.rav4world.com/forums/99-...2007-v6-coolant-replacement-3.html#post894535
http://share.qclt.com/丰田Toyota RAV4 Repair Manual/2AZ-FE Cooling/Coolant/01600310.pdf
Throttle Body Cleaning:
http://www.rav4world.com/forums/99-4-3-mechanical/116930-throttle-body-cleaning-2006-i4.html
Spark Plug Replacement
http://www.rav4world.com/forums/99-4-3-mechanical/85936-06-rav4-spark-plug-change-2.html#post928435
If you have any other good DIY guides, post a link! The search function for the forum is great (its how I found most of these), but its also nice having a central location for a lot of the common guides.
Surprisingly there is very few youtube videos for the transfer case and differential for a Gen3 model.
A note I wanted to pass along about the transfer case and the rear differential - Those drain and fill bolts are really set. I sprayed all four with penetrating oil to help break them loose and I still had to use a ton of torque. I used a 10 mm hex wrench and wedged the end into the circle end of a large combination wrench. I had to do this for each bolt and then pull (with steady pressure) as hard as I could. They all broke free with a "snap"! Each time I was worried I broke the hex wrench, but it was just the bolt releasing.
