Good job. It is satisfiing to do things right and for yourself. No question in your mind that it was done correctly is worth something in itself . Now that you have all the tools why not keep doing it in the future ?
Good job. It is satisfiing to do things right and for yourself. No question in your mind that it was done correctly is worth something in itself . Now that you have all the tools why not keep doing it in the future ?Never done an oil change in my life. Had all the right tools and consumables. No issues at all. Even torqued plug to 30ft/lbs. Cost: Mobile 0w16 on sale $31.99, filter $8.10, washer $1.50, environment fee $0.35, total $41.94 plus tax = $47.39 (US $ 35.53) .
Almost had fun. Took me over one hour. It’s tight under the truck, had to add 4 inch thick planks. The one thing I know for sure, everything was done by the book/specs. Got the right oil, right oil level, correct torque.
Would I do it again? It’s physically hard to do. Maybe next time I’ll go to Mr Lube, stay in the car, no appointment, no waiting, clean pants and sneakers – what’s 100 bucks more?
What do you guys think?
DIY oil changes while the car is under warranty means if something happens to the engine Toyota will have an excuse to deny warranty.Never done an oil change in my life. Had all the right tools and consumables. No issues at all. Even torqued plug to 30ft/lbs. Cost: Mobile 0w16 on sale $31.99, filter $8.10, washer $1.50, environment fee $0.35, total $41.94 plus tax = $47.39 (US $ 35.53) .
They would have to prove you damaged the engine first, by using incorrect fluid or incorrect filter, etc...The main benefit of DIY isn't to save costs but ensuring it's done properly. Many mechanics and dealers will 'forget' to change the filter, crush washer, or they overtighten the filter and/or drain plug. + Many dealers are using 0W-20 when they should be using 0W-16.DIY oil changes while the car is under warranty means if something happens to the engine Toyota will have an excuse to deny warranty.
Have never heard that one before. My car hasn't been to the dealer at all for nothing since I bought it 5 years ago outside of having an alignment done. Didn't even use the Toyota Care oil changes. Actually none of my vehicles have ever been to the dealer for any maintenance outside of recalls or warranty issues since new. One vehicle it was a leaking transmission gasket. The other it was a leaking oil pan gasket. The last time I had a car in the dealer or any shop for any mechanical work was probably 1995.DIY oil changes while the car is under warranty means if something happens to the engine Toyota will have an excuse to deny warranty.
Yes and you will also need to provide receipts and proof of the correct oil and filter were used that meet the requirement.They would have to prove you damaged the engine first, by using incorrect fluid or incorrect filter, etc...
Which shouldn't be a problem, if you keep all your receipts and maintenance records as you should be. Even easier if you order it all online.Yes and you will also need to provide receipts and proof of the correct oil and filter were used that meet the requirement.
This is simply untrue if you keep maintenance records and receipts.DIY oil changes while the car is under warranty means if something happens to the engine Toyota will have an excuse to deny warranty.
IMO if you follow the 5,000 mile/6 month interval then it shouldn't really matter if you get every last drop out. If you're concerned about sediment accumulating on the bottom near the threads then it's very simple to remove and reinstall the valve with an adjustable wrench, especially since the torque specs are only about half that of a standard drain plug. Just make sure you replace the crush washer afterward. (According to their website the threads don't stick into the pan.)Paul894 – Correct. And yes it’s not about the cost. I need it done right. Question: where do you put the jack stands in order not to damage anything? As for the drain valve, it looks like the thread is quite long and it seems to me that not all of the oil will drain out.
Yes.Can I take the filter off first?
That was my point in not understanding the two ramp thing when changing your oil. All of it doesn't drain out. You get more of it out level than you do at an incline. That is why when changing any fluids in your vehicle they recommend it being level and not at an incline. Some fluids it is more critical than others to have the vehicle level.SLS Artemis – That’s great if you can take care of your cars by yourself. For the 2 ramp thing, helps let all the oil drain out it it’s slightly inclined towards the back.
Please explain your thought process about changing the oil with the car been flat Vs front wheels beening elevated more oil draining out.That was my point in not understanding the two ramp thing when changing your oil. All of it doesn't drain out. You get more of it out level than you do at an incline. That is why when changing any fluids in your vehicle they recommend it being level and not at an incline. Some fluids it is more critical than others to have the vehicle level.
For your oil changes you'll obviously only need two, I posted the video to show the jack points and jack stands points as requested. Using a 3-ton floor jack + four matching jackstands on level ground is perfectly fine.I watched the 4 jack stand video and I think this is not right. Outright dangerous.
I would not do that. First, who has 4 jacks, and second most tires are directional
and have to stay on the same side and not cross over. But if you have to do it you can always put the spare tire in play for the rotation.
Understood. I noticed that two notches for a jack stand close to the wheel. Did not see that before. When I do my winter/summer tire changeover I always use the jack point on the axles. Quite convenient, like this I can do both front wheels and then rear wheels at the same time. To raise my Rav4 for the oil change I used two 2x6 wooden planks for an increased height of about 4 inches. Two more inches would be better. I have 2 jack stands that I could have used ..now I know, thanks. If I decide to do more DIY oil changes I’ll buy some ramps.For your oil changes you'll obviously only need two, I posted the video to show the jack points and jack stands points as requested. Using a 3-ton floor jack + four matching jackstands on level ground is perfectly fine.
Have a 2021 RAV4 Prime XSE w/6.6kW charger. It will come off the 2yr. warranty in August.Never done an oil change in my life. Had all the right tools and consumables. No issues at all. Even torqued plug to 30ft/lbs. Cost: Mobile 0w16 on sale $31.99, filter $8.10, washer $1.50, environment fee $0.35, total $41.94 plus tax = $47.39 (US $ 35.53) .
