1 - 15 of 15 Posts
I know occasionally people pop in here asking for parts or how to fix the rav4 trim pieces. Basically this takes about $177 paid to Toyota and 15-20 minutes to fix.
1. Lower top
2. Remove 5 screws 3 on outside vertical 2 on inside under clips.
3. Remove screws from horizontal just to give it some wiggle room putting in the new vertical.
4. Remove Vertical
5. Replace with new part.
6. Reinstall screws
New VS old Notice the broken trim that holds the top on the old
mensajero said:
This must be cool when you go to the beach.
It is nice with the top down, I want to buy a hardtop one too. They will be a lil bit less maintenance.
The trim parts will end up being the demise of this truck. By the time they break again they will be unavailable. The plastic just dries up and crumbles in your fingers.
give the trim a wipe with linseed oil occationaly, it will stay like new forever.
Soft top plastic trim repair for 1999 Rav4
What is the number on this part? I want to order but I don't know the namer or the # of the part?
Re: Soft top plastic trim repair for 1999 Rav4
Verticals
75605D MOULDING SUB-ASSY, QUARTER OUTSIDE, RH
**605-0W010 1997.12- SXA10, 15.. SOT 1
$108.09
$83.77
75606D MOULDING SUB-ASSY, QUARTER OUTSIDE, LH
**606-0W010 1997.12- SXA10, 15.. SOT 1
$108.09
$83.77
Horizontals
75608C MOULDING SUB-ASSY, QUARTER BELT, REAR RH
**608-0W010 1997.12- SXA10, 15.. SOT 1
$138.87
$107.63
75609C MOULDING SUB-ASSY, QUARTER BELT, REAR LH
**609-0W010 1997.12- SXA10, 15.. SOT 1
$138.87
$107.63
I know this is an old thread, but I just found this and I cannot thank you enough. Rag-tops are rare as it is, much less any considerable tips. Going to order some new verticals in a couple weeks and finally get rid of those pesky air leaks.
Discussion Starter #10
No problem man, glad I could help.
If your back window is gone you can use black fishing line to retie it, just get a piece of marine plastic vinyl and cut it to size.
Also check 3-4 online toyota parts places to price check the prices change all the time. Conecelli Toyota Parts is a good bet for a deal.
H
damm, here in Europe each Moulding costs around 140 € = 170 Dollars.
I did buy a new Softtop from a Softtop-Manufacturer made of woven tissue because the old one did shrink so much that it wouldnt take long to blast the new mouldings.
The stock Top is made of PVC and shrinks, its durable because its strong, thick but if left in the sun a lot its like Kashmir washed to hot.
DId anyone notice the difference in the attachment , instalation of left and rigth moulding, they are different designed, one with a design error, they didnt know , clip or not, what force has to be deflected, that I am so angry that they sell the wrong one as expensive as the good designed one.
Did anybody notice??
Flat
just got back from the dealer. parts obsolete.. now what? i need a new top, like everyone else.. but it won't do me any good without trim to hold it in. i will get my new top, i will replace these mouldings.. i know it would be a niche market be we are out here trying to save these ravs.. just no parts :/ i'll make some mouldings out of steel if i have to.
Hi guys, these bits are obsolete everywhere can we retire the stickey? From now on its time for qbond or similar, to rebuild what's left.
Verticals
$108.09
$83.77
$108.09
$83.77
Horizontals
$138.87
$107.63
$138.87
$107.63
Hi,
Are these parts still available?
I need these pieces but I didn't find them.
thank you
1 - 15 of 15 Posts
