The fuel service is worth doing as our little motors are direct injection GDI
The rest are up sell items unless you really need tires and at 38K you probably do
Seems like "oil change" interval would be more important as a measure of services that should be performed.Powering the 2020 Toyota RAV4 is a 2.5-liter Dynamic Force four-cylinder engine with DOHC 16-valve with D-4S Dual Injection and Dual Variable Valve Timing with intelligence. This engine produces up to 203 horsepower and 184 lb-ft of torque.
It’s port and direct inject and D4S has a self-cleaning cycle to eliminate carbon buildup issues. This isn’t comparable and is superior to standard GDI systems. It simply isn’t worth it on these engines, as there’s no history of common direct injection issues.The fuel service is worth doing as our little motors are direct injection GDI
All those are upsell to make money for the dealer; none are needed except for the tires depending on the tread depth left.Just moved to WA state from CA and took my 2020 Rav4 hybrid to the dealership for the warranty-covered 3k oil change. Mileage is about 38k. Always had good service from my CA dealership but took things into the WA dealership and after the oil change, they recommended a "threeway" fuel injection service that includes an air induction service (cleans the fuel rail and throttle body). The whole thing is a $360 service plus a recommended $190 brake fluid flush, plus a recommended $1230 tire mount wheel balance service. Now granted, I have put in at least 10 round trip long-distance drives between San Jose-Seattle since I bought the car and also I'm just hitting snow season so perhaps salt and crud is beginning to build up re: throttle body - but are these reasonable reccs or dealership marketing?
They are also port injected as well.The fuel service is worth doing as our little motors are direct injection GDI
This is an issue I'd never have but then my job is running Harleys up to their rev limiters at about 140 mph on a dyno. And on cars I tend to push the pedal on the right right to the floor quite often.It depends. My 2018 RAV4 (PFI) was not driven in the highway and at 20K the engine developed a knocking sound during start up. It would go away after warm up. I took it to the dealership. They found carbon buildup using a borescope. They performed some cleaning service and got rid of the loose carbon. The noise (carbon knock) went away.
Best word I think I've ever read on the forums - BAMBOOZLEDealer service writers generally receive commissions on the services which they can bamboozle the customer into accepting.
I now have a 2020 RAV4 Hybrid and I started to hear some of the same carbon knock, so I took it to the highway last weekend and drove for 4 hours at 80 mph. The loud carbon knock has practically disappeared and when I hear something, it is pretty quiet, but I am going to try another 4 hour drive this weekend to see if I can push it all out. Do I still need a cleaning or can a long drive do the trick?If you ever get to Connecticut I'll do a free carbon cleaning for you. But then you'd have to go on the highway to do that so go back to the dealer at 40K.
