Read your maintenance manual and know when service comes due and follow that. You can buy a tire depth gauge and check your own tires and shop for deals. I always stick to why I took it there in the first place and they can list what it needs on the work ticket. My first response to add on service is no, no and no.Just moved to WA state from CA and took my 2020 Rav4 hybrid to the dealership for the warranty-covered 3k oil change. Mileage is about 38k. Always had good service from my CA dealership but took things into the WA dealership and after the oil change, they recommended a "threeway" fuel injection service that includes an air induction service (cleans the fuel rail and throttle body). The whole thing is a $360 service plus a recommended $190 brake fluid flush, plus a recommended $1230 tire mount wheel balance service. Now granted, I have put in at least 10 round trip long-distance drives between San Jose-Seattle since I bought the car and also I'm just hitting snow season so perhaps salt and crud is beginning to build up re: throttle body - but are these reasonable reccs or dealership marketing?
Just buy a brake fluid tester if there is now water in the fluid there is no need to change it.Brake fluid flush is an important but often overlooked service. The only owners manual that I have seen it specified was for a 1984 Mercedes 300TD. I’ve replaced brake cylinders due to rust and corrosion. If there was flushing done the cylinders probably would have been fine.
In theory old brake fluid attracts moisture that could cause loss of braking performance under extreme circumstances because the moisture boils. In reality I doubt that there could ever be enough heat buildup for this to happen.
Perhaps. If the sample in the top of the reservoir is representative of the entire system. If moisture is the only contamination of concern. Water tends to fall to the lowest point. Moisture can permeate through the rubber hoses and rubber at the calipers and wouldn’t make it to the reservoir. Every time I have rebuilt a cylinder there was black particles there. May be particles from rubber wear. Flushing would help remove it.Just buy a brake fluid tester if there is now water in the fluid there is no need to change it.
😂 LOL. Having California plates in states being overrun by people escaping the political environment in California could make your vehicle a target for unwelcome attention.Do you still have your California license plates on the vehicle? If so, get rid of them ASAP and get Washington plates......
Just did another Harley today. Made a dozen runs to the rev limiter at various throttle openings. Sounded great even thru my Decibel Defense hearing muffs.This is an issue I'd never have but then my job is running Harleys up to their rev limiters at about 140 mph on a dyno.
that is perfect way to break in the engine and gears !! freeway runs at 4am but on a dyno is nice i can rev every single gear up and let it back down.Just did another Harley today. Made a dozen runs to the rev limiter at various throttle openings. Sounded great even thru my Decibel Defense hearing muffs.
Tuning: $400. Decarbonization: free.
Out west, we call that a freeway or open road.a dyno is what I need at home to blast away carbon deposits
a dyno is like a treadmill for the carOut west, we call that a freeway.
Can't do that there in Honolulu without running into someone even 50 feet away.Out west, we call that a freeway.
You can take a sample from caliper bleed valve.Water tends to fall to the lowest point. Moisture can permeate through the rubber hoses and rubber at the calipers and wouldn’t make it to the reservoir.
I've owned cars where a three year brake fluid flush and refill was manufacturer recommended. And was a requirement of the track within two weeks of any high speed event no matter the age of the car.There is no way that there is any meaningfull amount of water in the brake fluid of a 2 or 3 year old car, unless its a flood salvage.
