1 - 17 of 17 Posts
Its about 100°f in Texas right now, I keep my interior temperature on auto 70-76 depending on how I feel, but I eventually keep the fan speed on the lowest when the cabin gets cool enough.
Always on manual and set as low as it will go temperature wise. I adjust fan speed as I feel the need to. The auto and dual settings have zero use for me.
Both! :wink
Always on Automatic.
Auto always. Set to temp I want and forget about it.
This is the third car I owned that have auto-climate and all of them is set on auto year round.
I keep it in Auto all the time. Usually set it between 75-78 depending on how hot it is outside. Contrary to what some people think, when the inside of the car is 120+ degrees, it cools off just as fast at 78 as when it is set to LO. Rarely do I set the fan speed--I just lower the temp when I'm hot and raise it when I'm cold.
When the windows are closed, it's on Auto - usually 24 C. If the weather permits, I much prefer driving with the windows/sunroof open though.
The only adjustment I make is to turn off the recirc to allow fresh air in after a while. With it being so hot lately, the recirc stays on for a long time and the interior air can get a bit stale.
I usually leave it on auto. Sometimes I adjust the fan speed but usually not.
I have never seen the recirculate light off so it must always stay in recirculate mode when in Auto?
Also, do you turn the system off before shutting the engine off or just turn the car off?
Just turn car off only.
...........I have never seen the recirculate light off so it must always stay in recirculate mode when in Auto?
When you turn on the system in Auto recirculate is ON and will stay on until you cut it OFF. Helps to heat/cool interior faster.
I always cut system off before turning off the engine - but that's just how I do it.
I always turn the A/C off a few minutes before I get to my destination whether in auto mode or not to eliminate any moisture in the system to prevent mold build up that makes for a stinky HVAC system, then there's no need to use chemicals to fix it, has worked for me for decades of driving A/C equipped vehicles. :wink
Always use it on Auto as my wife and I like difference temps. We just set the temp (72 degrees F) and let the computer do the rest.
1 - 17 of 17 Posts
