This might helpWhere exactly did you insert the line to clear them?
Thanks. I will add this to my list of tasks to do. 😀This might help
That hose goes outside on the passenger side. Better to get under the car to poke through the hose because all the water can drain outside than inside the car.Thanks. I will add this to my list of tasks to do. 😀
Yeah, I learned that the hard way!!That hose goes outside on the passenger side. Better to get under the car to poke through the hose because all the water can drain outside than inside the car.
Oh man! I hope I do not need to complete the same mission...lolI had a pool of on the passenger side footwell. After a lot of research and testing I found there was a tiny gap in the windshield sealant just under the A pillar trim. The windshield had the OG window codes so I'm pretty sure it was stock. But I had to yank all the carpet up on the left side, pull the bungholes open and clean the mold and treat under the seats for surface rust with rust convert and a wire brush.
What a mission that was.
