Hello recently I’ve had power window issues on the driver side of my 2006 RAV4. All other windows work except the drivers side. I can control all three windows from the master switch except the driver one. It does not go down. I replaced the master switch, checked the fuses, and checked the power window motor. None of those attempts worked. Any help? Thank you.
How did you check the drivers window motor? Did you run a temp power and/or ground wire direct to the motor?
Ok, no power to the motor. I'm not familiar with the wiring diagram, but I'd say to start with the driver window switch and see if there's power on the terminal to the motor when pushing down on the switch. There's posters on here that can provide the wiring diagram or describe the location of the terminal. That's beyond me!
Good luck.
