Hi everyone!
I'm new to these forums but I just have a quick question
My girlfriend has a 2004 Toyota rav4 and recently her driver side window stopped working.
The other three windows work fine as well as the window lock button it does what it is suppose to do.
I was wondering if this would be a bad window motor inside the door panel? Or if there is anything else that I could check before taking apart the door panel.
Thank you!
First thing to check would be the fuse. Each window has a separate fuse. Then check the switch. Then remove the door panel and check the motor and regulator.
Where would these fuses be located? I checked under the hood and underneath the steering wheel? Any help would be greatly appreciated.
And if there is anyway to check the switch.
Thank you!
Thank you!
The fuses should be under the dash. To check the switch you would need a multi-meter. The switch panel can usually be pried up and out of the door. Look for a Youtube video on removing the door panel.
