Confirmed.Canadian Ravs had DRLs IIRC.
The Daytime Running Light Module is interconnected with the ABS Sensors, you'll notice if you park infront of a glass front building that the headlights only turn on after the wheels have made either half or a full revoloution, when the vehicle is in a drive gear.I just got a build report on a 99 Rav4 (junkyard car) and it says that it had DRL as an option.
Was that an option released in 1999? It is included in the ABS option code.
They connect it to the ABS so if the vehicle detects enough ABS activity in a certain amount of time, does the horn go "AAAAAAAAAAAAHHH!!!!"?The Daytime Running Light Module is interconnected with the ABS Sensors, you'll notice if you park infront of a glass front building that the headlights only turn on after the wheels have made either half or a full revoloution, when the vehicle is in a drive gear.
