So my wife's 2006 RAV4 V6 2WD 155k mi has been making a dull loose noise for some time and is getting more prevalent. Occurs when driving straight and going over bumps so I've ruled out the dreaded steering shaft knock (I have that too). This sounds like a loose front suspension component. It's not repetitive, kinda random sequence. I've jacked up vehicle, checked everything up front and in the rear and can't find anything loose. Only slight axial movement in CV axles.
I have searched for days to pin-point it and everything leads to the steering shaft knock/popping. This isn't that. I found T-SB-0308-08 for Steering Rack Noise which the description sounds like what I have. I saw somewhere online where a faulty steering rack would actually have slop and move slightly under load. Mine is tight and doesn't move so I'm questioning if this is the problem.
Any insight would be greatly appreciated. My last resort is going to the dealer to diagnose. Does the dealer fix TSB issues for free? Last time I went to dealer for transmission flush, I came home with a transmission pan leak.
Thanks to all in advance.
Darren
Darren
