1 - 2 of 2 Posts
I have a Limited 2012 V6 4x4 Rav with push button start. I was wondering if this model has any hidden features (easter eggs)? For example, on my 2006 Highlander if I hold the key in the lock postion in the door key hole, the windows will close.
Thank you
Brandon
One that I can think of is on your SmartKey fob if you hold both the lock and unlock buttons down at the same time for about 6 seconds it will toggle the unlocking of all doors or only the driver's door when you either use the fob or touch a front door handle. The vehicle will beep at you when the change is made.
Also, the metal key in the SmartKey fob can be used to lock the glove compartment (or unlock the driver's door if the battery in the fob dies).
1 - 2 of 2 Posts
