Hello,
I am super confused as to what is going on. 1996 RAV3 4x2 Manual.
Car works fine for a while then it will start blowing the EFI fuse. It blows as soon as you turn the ignition on and won't allow the car to start. I pulled up the wiring diagram and have disconnected all the sensors that seem to be on the circuit. Also unplug at lot of other sensors. Turn the ignition and the fuse is still blowing. I also move wiring harnesses to see if those are spots for the short. Same result, EFI fuse still blows out.
The only fix I have found for this is to unplug the ECM. Then turn the key and it will stop blowing the fuse. Reconnect it and it goes back to normal, car will start. Will not blow the fuse for another while, couple days. Is that a sign of a shorted ECM? I have also left the battery unplugged overnight and that doesn't get rid of the fuse blowing until I unplug the ECM.
Any insight on what this maybe would help me as I am so confused. Debating just replacing the ECM to see if that does it.
Thanks.
Thanks.
