EG010-02 / M.I.L. "ON" P0420 or P0430 / 04-12-02
5045 Views 5 Replies 3 Participants Last post by  catia1313
TSB Number: EG010-02
Bulletin Title: ECM CALIBRATION UPDATE - M.I.L. "ON" DTC P0420 OR P0430 ENHANCED ENGINE PERFORMANCE
Release Date: April 12, 2002
Applicable Year(s): 2001-2002 (VIN Specific)
File Size: 154kb PDF
Download: http://rav4world.com/tsb/EG010-02.pdf
Description: The Eninge Control Module (ECM) calibration has been revised to enhance Engine Performance and to prevent a M.I.L. "ON" with DTC P0420 (Bank 1 with Catalyst System Efficiency Below Threshold) or DTC P0430 (Bank 2 with Catalyst System Efficiency Below Threshold) under certain driving conditions.
R4W Comments:
G
My 2002 Rav4 seems to be affected by this TSB. But the TSB says it concerns VINs produced before VIN numbers listed for two different factories: Tahara and Shokki. My VIN is before the VIN cutoff on the Shokki factory, but after the VIN cutoff on the Tahara factory.
How do I know which factory made my Rav4?
I need a copy of this so I don't have to replace the cc again.
The link to the pdf is empty:there is no pdf.
Can someone please post the pdf or a link to it?
Am having issues getting car inspected-no one can find the tsb
Also the site is not working properly for me. Help Please.
Much appreciated!
I need this TSB as well!
My 2001 has 238,000 miles on it and is still kickin!
My mechanic said they can go 300k to 500k and are a great vehicle.
Thats from a guy who owns the shop.
I downloaded the TSB info & instructions, from alldatadiy.com & did take my 02 Rav 4 to the actual dealership (Rorich Toyota Pittsburgh)where it was purchased, because all of the service records indicated this update was never performed. Also, I did not have the sticker that is required to be applied under the hood to indicate it was performed. I also asked them to check to see if the issue was caused by anything else.
1st I was told my car was out of warranty, & I said yes, I understand, & I will pay for the update. They gave me an appointment date & I dropped my car off.
When I went to pick it up, NOTHING was done. 1st they said it had already been performed, I showed them the print outs of all of the service records & it was not performed. Then they came back & said "the TSB is obsolete", I asked them to do it anyway because I have no problem paying for it & they flat refused to perform the update. They said I needed to just replace the CC. I had to explain, again, my car is super low miles (02 rav4 under 40k mi), & it is on the 2nd CC, another CC replacement makes the 3rd CC. I explained that the TSB is not obsolete on my year of Rav4-it did not matter what I said, they just refused to perform the TSB.
Anyway, the TSB has still not been performed. I have no idea what I can do about this.
I will have to get the CC replaced (not at the dealership), still haven't done it yet.
I do not know if someone other than Toyota will do the update or if they can. This is the problem. Going to this dealership was like hitting a brick wall. They do not want to do it because it is an 02 & not one person there seemed to understand what I was talking about when I explained OVER & OVER that a car with less than 40k miles should not need the CC replaced twice. They kept referring to the year-I said "it has less than 40k miles this will be the 3rd catalytic converter!!!". They just said "that's the code it's throwing" it just went around & around in a circle. I even asked if they checked anything other than the code reader to see if it could be the O2 sensors or something, they said they do not do that--because it threw the code & that is what it is & there is nothing to check. I said "well that is what I made the appointment for"
. This was actually the point where I left because I KNEW it was BS
Any idea what I can do about it?
Are there independent mechanics that can perform the TSB or is it a dealership only fix?
