Seems to be the way of the future.
Eliminate a power consuming hydralic pump used for steering and replace it with a electric motor assisted steering rack.
Anyone hear what the long term reliability expectation of this new approach should be??
Discussion Starter #2
Must not be any problems.. 151 views and no comments..
System defaults to manual steering mode if a fault is detected.
"In case a malfunction occurs in the system, the fail-safe function stops the output current and reverts the control to manual steering. At this time, a P/S warning light illuminates to alert the driver of the
malfunction."
I remember reading in the manual that the motor may shut itself off if it heats up too much as a percaution. ex. Trying to park a trailer in reverse, all the turning back and forth might cause the motor to shut off, but will come back on after it has a chance to cool down.
So if in the future you do get the PS light, try letting it cool down for a bit to see if that fixes the problem.
B
FIAT haveing been using electric power steering for years without problems. In fact, it seems to be the only part of the series 2 Punto that didn't give problems. If FIAT can make it work, I wouldn't worry about too much about Toyota
