ENGINE MAINTENANCE REQUIRED ! So annoying
67300 Views 147 Replies 41 Participants Last post by  Tazio Nuvolari
I took my 2019 rav4 to the dealership for regular maintenance , when I left the engine maintenance required show on my dash and it’s not going away. I did change the oil just recently too.
Any solutions?
1 - 20 of 148 Posts
Yes I did , like 100 hundred times
Still showing engine maintenance required.
Reactions: 1
If you reset it correctly it should not be showing make sure you ok the reset. It automatically comes back on after 5 or 6k miles.
I did it correctly
I been watching plenty videos of how to reset the maintenance required not the engine maintenance required
My car is showing engine maintenance required not maintenance required
All the videos that show how to reset it is about the issue when your car shows maintenance required not engine maintenance required
I read in other forums about my problem and some people are driving with that in their dashboard for like 2 months. They still can’t figure out.
Reactions: 1
I did it correctly
Try the solutions set forth in these posts. Font Screenshot Software Multimedia Electronic device
Rectangle Font Screenshot Number Logo
If it's an engine service light it will not stay off if there is problem detected you need to have it checked at the dealer.
Reactions: 1
It sounds like a CEL thing more than a PM service reminder. Why didn't you turn around and ask the dealer? I'm not a big believer in coincidence, and that's a bit too coincidental.
Even if it was just the service reminder message - you paid for that !
Try the solutions set forth in these posts. View attachment 172940 View attachment 172942
This save my life.
Thanks a lot to everybody for the support.
Finally fix the problem.
Reactions: 2
This save my life.
I feel you!, it was very annoying
I found an solution for this, I don’t own a RAV4 or any Toyota products but, I do work at Enterprise Rent A Car and most vehicles I work with has some kind of problems. This 2020 RAV4 had the same issue about “engine” maintenance required.
The solution I found as I were browsing the settings, if you press the Menu button on the display screen, go to setup, then scroll down to see vehicle, then vehicle customization, last but least Convenience Services and basically turn it off. You can turn off the vehicle and re-start it up, “engine” maintenance require won’t pop up “if” you did the steps correctly. Google wasn’t any help on this, so I had to figure it out myself. Turning off convenience services is an temporary fix but, at least the message is off.
Reactions: 1
Any solutions?
I just had the same problem with my 2020 Toyota Corolla SE. I have 88,000 miles because I drive for Uber and Lyft. Anyways it was this same coolant bypass valve that cracked and started leaking on mine too and shorted out the part where the harness plugs in.
The dealer wanted $600 to replace it but I just bought the part for $125 and did it myself. Took about one hour not a big deal. I also spent $25 on a gallon of Toyota red coolant as well. You lose a little bit when changing it.
Reactions: 1
Hello everyone I have the same issue and here is what it looks like any help. No code are showing and I do not know what to do.
Speedometer Vehicle Gauge Automotive lighting Font
Stop at a Autozone and have them read the CEL from the ODB-II port.
I’ve had it ran for codes and nothing came back. It drives fine and handles well
It's no big deal just reset it, It's just a reminder for oil change or tire rotation or what ever. You can reset it using the dash screen menu it will come on every 5 to 6000 miles.
I have Reset it numerous times
Maintenance light does not set codes cause it's just a light (Engine light) does.
yeh it just says across the screen next to the speedometer, “engine maintenance required”
The std used to be "Vehicle Maintenance". Anything "Engine" was reserved for CEL.
So, if Toyota changed something, then they made a mistake.
1 - 20 of 148 Posts
