I have a 2012 RAV4. V6 74000 miles. Upon cold start, intermittently only, I get a mechanical interference noise .Almost sounds like the starter not disengaging. The dealership has replaced some cam guides in engine says there is an issue with these,also on another visit they said it as a bearing going bad on water pump and replaced it. Both were done at no cost to me. I am trying to get noise on video to no avail. Any thoughts?
Welcome! If you could post a recording of the sound that may help members try to diagnose the cause.
If you're talking about the little half-second grinding sound when starting the engine cold, it's been discussed here for years. The consensus is it's normal because the oil has drained out from the top of the engine. It sounds bad but there is no long term damage.
Engine noise on cold start
Thank you for replying to my concern, I am glad to here that this is not doing any damage to my engine.
